Old 03-30-2017, 01:45 AM   #1
monstertdm
Front lowering spindles - still confused
So after much reading and searching i am still confused as to which lowering spindles will move my tires IN on a 1987 GMC 2wd SWB (needing some additional clearance with the current tires and wheels that came on it). Is it only the CPP modular or are their other choices? Sorry if this is beating a dead horse just want a definitive answer before i go shopping. TIA
monstertdm is offline   Reply With Quote
Old 03-30-2017, 05:06 AM   #2
bbbc10
Diggin The SquareLife
Re: Front lowering spindles - still confused
spindles push out the wheels only cpp keeps them in the same spot
bbbc10 is offline   Reply With Quote
Old 03-30-2017, 09:29 AM   #3
JohnJ@RideTech
JohnJ@RideTech's Avatar
How low are you looking to go?
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 03-30-2017, 11:30 AM   #4
monstertdm
I am hoping for a 5/7 drop johnj
Old 03-30-2017, 11:40 AM   #5
JohnJ@RideTech
Ive got some pieces to get you down to a 4/6. We use the CPP spindles in our kits and they work really well. I will try and attach a picture of our Square Body so you can see how it sits.
Let me know what you think about the height.
Name:  Square Body Side.jpg
John J.
Sales/Tech
Old 03-30-2017, 11:49 AM   #6
monstertdm
I like that stance jihnj. Which cpp spindles did you use?
Old 03-30-2017, 11:52 AM   #7
JohnJ@RideTech
It is their C10 HD spindle. Check out the link below.
http://www.ridetech.com/store/1973-1...p-spindle.html
John J.
Sales/Tech
Old 03-30-2017, 11:59 AM   #8
monstertdm
And you had no track width change when you installed those correct?
Old 03-30-2017, 12:03 PM   #9
monstertdm
This is what is confusing to me, "Note: Bracket required when using stock 12" brake components. Puts wheels at stock drum offset" from cpp website. Is the stock drum offset wider, narrower or the same as my truck now?
Old 03-30-2017, 01:07 PM   #10
JohnJ@RideTech
That truck had factory disc brakes when we installed the kit so I am unsure. I will ask around and see if any of the engineers know the difference in offset between the disc and drum brakes.
John J.
Sales/Tech
Old 03-30-2017, 01:18 PM   #11
SCOTI
SCOTI's Avatar
Disc brake trucks have a wider track width vs drum brake trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-30-2017, 10:26 PM   #12
coreyjhen
Attachment 1637122
What size wheels/tires are those? They fill up the wheelwells very nicely.
coreyjhen is offline   Reply With Quote
Old 03-30-2017, 10:31 PM   #13
bbbc10
20s
Old 03-31-2017, 08:03 AM   #14
JohnJ@RideTech
The truck has 255-45-20s on it, the same all the way around.
They are Legend Series wheels, we have US Mags on our other C10 that look very similar.
John J.
Sales/Tech
