Old 03-30-2017, 06:47 PM   #1
samkost
samkost's Avatar
Question New Wheels Advice Please
I have a line on purchasing some Corvette Ralley wheels for my 72' C10 and could use some of your advice and opinions.
Will a 15X8" 4.25 back spacing with a 3.75 offset wheel be correct for my truck?
Will these bring each tire/wheel outward a bit in their respective wheel well compared to the original truck ralleys? I would be happy if they did.
I just want to confirm that these will mount up to my 72' correctly with the stock Disc Brakes/Rear Drums.
Sam
samkost is offline   Reply With Quote
Old 03-30-2017, 06:54 PM   #2
OARNGESI
OARNGESI's Avatar
Re: New Wheels Advice Please
Same with and BS 295 50 15 245 60 15 tire 3/5 drop
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-30-2017, 07:09 PM   #3
James the III
Sam
make sure these are the large car and truck 5 on 5 lug pattern not the 4.75" car /vette pattern
James the III is offline   Reply With Quote
Old 03-30-2017, 07:10 PM   #4
rharris
rharris's Avatar
original truck rallys (assume the 73 and up) are 4" back spacing. So the wheel would be towards the inside 1/4" more with your vette rally's I have learned that a 1/4" from this wheel to that wheel can be different. I am going to use 4 1/4" backspacing steelies (72) with 275/60's - the front look really close without the tire. I will let you know how I make out. Good luck. If anything you may have to play around with front tire size. I think I said that right.....check out below link.
http://www.autoanything.com/wheels-r...el-backspacing
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 03-30-2017, 07:18 PM   #5
samkost
samkost's Avatar
Will do!
This is why I enjoy learning from this forum.
What would be the tallest and widest tire size to mount for filling up the wheel well?
I was thinking 285/60/R15 ?
Thanks James
Old 03-30-2017, 07:41 PM   #6
samkost
samkost's Avatar
O.K. Great info here.
I'm learning to understand the formula relating to backspacing.
I currently have the original 15" wheels on my C10, so are they a 4" back space also?
Thanks rharris
Old 03-30-2017, 07:48 PM   #7
rharris
rharris's Avatar
those look to be 7", and I do believe the backspace is the same on the truck rally's at 4". I had 255/70/15's on my old 71 GMC. Height was very nice and width wasn't bad either.
Old 03-30-2017, 08:16 PM   #8
geezer#99
geezer#99's Avatar
Here's some info on backspacing/offsets in both metric and standard.
http://www.rimsntires.com/specspro.jsp
Old 03-30-2017, 08:24 PM   #9
samkost
samkost's Avatar
Thanks for the stance/tire photo of your GMC rharris.
I don't want to deviate too much.
My C10 has been lowered/leveled slightly with lower coils.
Currently running P235/75R/15's.
It think it needs some taller tires
My vision is to just fill up the wheel wells a bit more.
Trying to find a happy medium.
Thanks again,
Sam
Old 03-30-2017, 08:26 PM   #10
CC69Rat
CC69Rat's Avatar
Will do!
Thanks James
Is the truck lowered at all? Stepside or Fleetside?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-30-2017, 08:34 PM   #11
samkost
samkost's Avatar
Thanks Geezer for the link.
CC69Rat, Yes, Fleetside and slight drop with coils.
Old 03-30-2017, 08:35 PM   #12
CC69Rat
CC69Rat's Avatar
sorry about that, our posts hit about the same time.
To figure out your tire size and what you have now, vs how much bigger you want to go..
I'll use your example. 285/60/15
The first number of course is the width, but it's metric so let's convert that to inches first. 285 ÷ 25.4 = width in inches.
Then whatever that comes out to be (don't have a calculator at the.moment) multiply it by the aspect ratio. X .60
That will give you the height of the sidewalls. So, from the bottom of the wheel to the ground and from the top of the wheel to the top of the tire. We have two of those.. so, X2.
Then add your wheel diameter in inches.
285 ÷ 25.4 x .60 x 2 + 15
Just adjust your formula and you'll find a tire you're happy with. From an overall height perspective it can make or break the looks of your truck, absolutely. I usually try to find a tire the rear sidewalls are just a little more than the front but not a lot. And likewise in my opinion it looks kinda off if the sidewalls up front are bigger than the back, just so you can fit a wider tire under it. Hope this helps
Chad
Old 03-30-2017, 08:51 PM   #13
samkost
samkost's Avatar
Thanks Chad,
Some great info you have sent.
When I said I didn't want to deviate too much, there is alot to consider.
I definitelty don't want to throw off things like the speedo and of course its great comfortable coil spring/sway bar ride.
Many Thanks
Old 03-30-2017, 10:17 PM   #14
James the III
I'd love to know if those thin chrome or maybe they are s/s trim rings work on the 70-80's truck ralleys..
As I'm not fond of the stock 3-4" wide ones on the truck and vette ralleys.. normally..
thin trim
Old 03-30-2017, 10:31 PM   #15
samkost
samkost's Avatar
James,
Is this what you are suggesting?
http://www.classicindustries.com/shop/search/?q=TR3125 or
http://www.classicindustries.com/pro...ts/tk3015.html
They expose the wheel slots a bit more?
Old 03-30-2017, 10:32 PM   #16
RGT
Tire rack has a great data base of tire sizes and actual dimensions, I always find myself here when figuring which tires to run;
https://www.tirerack.com/tires/tires...omCompare1=yes
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering.
RGT is offline   Reply With Quote
Old 04-08-2017, 01:07 PM   #17
rharris
rharris's Avatar
Samkost - below are 4.25" backspacing with 275/60/15. The tire is about a small fingers width to the upper control arm.
Old 04-08-2017, 02:10 PM   #18
randy500
Nice looking super...I like the way it sits, not lowered at all right? Seeing it in green and white makes me re-think changing mine to black and white.
randy500 is offline   Reply With Quote
Old 04-08-2017, 02:16 PM   #19
randy500
Thanks rharris
Those are truck ralleys on your truck and I am almost certain 8" wide ones. Be careful on the purchase of vette ralleys, chevy never made them 8" wide with 5 x 5 truck bolt pattern.
Old 04-08-2017, 05:25 PM   #20
rharris
rharris's Avatar
Original suspension in picture. Planning on 2/3 drop.
Old 04-08-2017, 07:11 PM   #21
samkost
samkost's Avatar
Thanks guys for your replies.
Sam.
