Old 03-30-2017, 07:35 PM   #1
Someday
Someday's Avatar
Brake light in dash
I have a question about the brake light in the fuel level gauge. Mine comes on when I start the truck, but not when I apply my parking brake. Is this light supposed to come on when I apply the parking brake? Is there a switch attached to the parking brake pedal?
Thank you for any help!
1971 Chevy SWB Fleet. 250 w/ 3 OTT
Someday is offline   Reply With Quote
Old 03-30-2017, 07:49 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Brake light in dash
It's working exactly as designed.
Actually it should come on if there's a pressure unbalance in the braking system, like from a loss of fluid. No parking brake switch.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-30-2017, 08:05 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Stomp on your brake pedal REALLY hard, that will usually cure the problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-30-2017, 08:11 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ That sometimes works if the light stays on, but he doesn't seem to have that problem. His light comes on momentarily when he starts the truck, which is normal. That's what I am assuming anyway.
OP, help clear this up please!
- Mike -
RIP El Jay
Old 03-30-2017, 08:13 PM   #5
custom10nut
custom10nut's Avatar
Our trucks didn't come with a "Parking Brake Indicator" light, but Andy posted a thread on how to hook one up.
I have my set up ready to go in.
custom10nut is offline   Reply With Quote
Old 03-30-2017, 11:28 PM   #6
Someday
Someday's Avatar
Yup, just comes on momentarily on start up. I thought it was also supposed to come on when the parking brake was applied. Thank you for clearing this up, I really appreciate the help!
Old 03-30-2017, 11:48 PM   #7
jocko
jocko's Avatar
yes, that's normal. If it comes on after start, it indicates a pressure differential between front/rear brake systems and lets you know you're soon going to be stopping on only the fronts or only the rears once the leaky system leaks out - i.e. time for a checkup! Often an indicator of a leaking wheel cylinder.
