Old 03-31-2017, 04:15 PM   #1
Jeepwm69
R4 compressor
I have an 83 GMC with A/C that will actually work fine for awhile when I charge it, but has a leak in the factory R4 compressor.
I'm guessing putting seals in one of these isn't easy, so thought I might just get a new compressor.
Rockauto has everything from a $113 closeout "Vista Pro" to a $202 AC Delco.
I'm guessing new would be safer than rebuilt, and where all should I replace O rings in the system before I recharge it?
Jeepwm69 is offline   Reply With Quote
Old 03-31-2017, 10:27 PM   #2
andyh1956
Re: R4 compressor
I dumped all my R4s & went Sanden.
andyh1956 is offline   Reply With Quote
Old 04-03-2017, 02:47 PM   #3
Jeepwm69
Re: R4 compressor
I'm familiar with Sandens as that's what my Jeeps have, but won't that require new/ different compressor mounting brackets as well?
Old 04-03-2017, 02:52 PM   #4
jjzepplin
jjzepplin's Avatar
Re: R4 compressor
They run about $50. I made my own for about $5. Not as nice but works just fine.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-04-2017, 12:29 AM   #5
andyh1956
Re: R4 compressor
Yeah they make adapter brkts for them
Old 04-04-2017, 11:25 AM   #6
Jeepwm69
Re: R4 compressor
Is there a particular source you can recommend for brackets? Anything else needed to swap to a Sanden style?
Is there an inherent design flaw in the R4 or what? Mine works fine when charged, but has a leak in the compressor.
What is the benefit of the Sanden (I'm guessing that's the A6 model compressor I see listed, right?)
Old 04-05-2017, 11:40 AM   #7
andyh1956
Re: R4 compressor
This isn't what you need, but I've used two of these on serp front engines.
http://www.tbiproducts.com/index.cfm...prod/prd20.htm
http://www.tbiproducts.com/pdf/R-4_t...08_Bracket.PDF
On engines like yours people like Alan Grove mounts.
The r4 is the Vega of the compressor world. They work, but don't work as good as others. They like to leak (As you already know) They shave piston rings off & clog up the orifice tubes & don't never ever use one of the "Variable Displacement" r4s!
Old 04-05-2017, 11:55 AM   #8
Jeepwm69
Re: R4 compressor
Good to know. I'll look up Alan Grove mounts and plan on putting an sanden on the truck when I get ready to clean out the A/C system.
Old 04-05-2017, 12:19 PM   #9
Jeepwm69
Re: R4 compressor
Interestingly enough, Dad's 95 GMC apparently has an R4 that recently crapped out too. Wonder if I shouldn't do the same thing with his?
