Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 03-31-2017, 09:10 PM   #1
animal12
C60 floor pan
hey folk's , wonderin if the floor pan's will interchange between a C10 & a C60.
I have a sumthing 60 C60 & the driver's floor is gone . I know that LMC & I think Brothers sells floor pan part's for PU's & need to know if they will fit in the larger C60
tks
animal
if the thunder don't get you
then the lightning will
animal12 is offline   Reply With Quote
Old 03-31-2017, 10:29 PM   #2
sweetk30
sweetk30's Avatar
Re: C60 floor pan
most all c-40-up stuff the floors go a lot flatter than c-10-c-30 stuff. from what I have seen . . . mabye someone else will know more specifics.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-31-2017, 10:50 PM   #3
Re: C60 floor pan
They are certainly different, but possiblt could be altered to work. Could be easier than total fabrication, but maybe not so much. Maybe someone with experience in this will comment. From the cowl down to the floor aand to back panel the medium duties have different sheet metal. Also, they run straight rail frames while light trucks take a bend upwards over the front suspension.
Old 05-10-2017, 12:01 AM   #4
JPBrecheisen
Re: C60 floor pan
The floor pans should work ok with some finessing. Like others have noted, the center sections is the big difference, but when I say this, I'm talking 60-66 model years as those are what I'm most familiar with.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
