Old 04-01-2017, 02:02 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Bulb Change on HVAC Control
I need to change the bulb on my HVAC control in my truck that has factory A/C. The bulb beside the fan switch is a real bear to get at so my question is, if I remove the two screws that hold the HVAC Control in place can I pull it forward enough so I can get at the bulb. There must be someone on here that has ran into this bulb change .
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-01-2017, 07:37 AM   #2
68panelman
68panelman's Avatar
Re: Bulb Change on HVAC Control
It's been a long time for me since I pulled one, but I believe it will only come out from the bottom, not threw the opening. You should be able to grab the two bulbs from either side of the assembly, they are a pull socket.
68panelman is offline   Reply With Quote
Old 04-01-2017, 10:09 AM   #3
kaycee
kaycee's Avatar
It gave me enough room to pull the unit out from under and work on the fan switch and bulb . So yes pull the 2 screws and push the unit in and down to gain access
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-01-2017, 10:44 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Bulb Change on HVAC Control
I've never had a problem with them. They are angled in so they are not bad at all to me to get out are in without pulling it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-01-2017, 11:53 AM   #5
kwmech
Ditto, I've never had to pull the unit out to change bulb
