Old 04-01-2017, 01:55 PM   #1
brans72
upper control arm rubbing top of spindles
Looking for little help here guy's!
Working on my wife's 67 C10 with 83 C10 front subframe complete with upper and lower control arms from 83. I installed drop spindles from ECE and when you cycle the wheels the back of the upper control arms it the top of the spindles.
Truck does have new ball joints yet to grease my buddy is bring my grease gun over tonight from work. Truck has been apart for couple years so Could be something simple actually.
Hoping for a quick fix before I take upper loose at ball joint and trim it up some.
Anyone help a guy in a jam out? Thanks Brandon
brans72 is offline   Reply With Quote
Old 04-01-2017, 06:47 PM   #2
SCOTI
SCOTI's Avatar
Re: upper control arm rubbing top of spindles
Is the suspension compressed or extended? Check clearances w/it compressed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-01-2017, 10:03 PM   #3
brans72
Compressed with engine and transmission in frame rails, no other body parts installed.
Thinking might need to trim little on upper arms.
Old 04-01-2017, 11:35 PM   #4
sprint_9
sprint_9's Avatar
If you had the upper arms off, are you sure you have them on the right side, and not flip flopped?
sprint_9 is offline   Reply With Quote
Old 04-02-2017, 07:24 PM   #5
PGSigns
PGSigns's Avatar
It will clear fine once you have more of the truck together, no where near enough weight to start to worry about it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-03-2017, 10:46 PM   #6
brans72
Think so slot for brake line bracket thing is on back side.
Got a pic I can reference?
Old 04-04-2017, 07:42 AM   #7
PGSigns
PGSigns's Avatar
On an 83 the brake lines are on the front of the upper A arms.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
