Old 04-01-2017, 02:05 PM   #1
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Thorley BBC header ID help
Can you help me identify the application of each of these?
I have 4 sets.
And one set I had made into 3" collectors...
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 04-01-2017, 02:07 PM   #2
RPOZ11
RPOZ11's Avatar
Re: Thorley BBC header ID help
Here is the 2'nd one from the top fitted that had the tubes stacked near the collector
HO72 build :
2017 SS
Old 04-01-2017, 02:27 PM   #3
RPOZ11
RPOZ11's Avatar
Header 3'rd from the top with stacked tubes before the collector :
HO72 build :
2017 SS
Old 04-01-2017, 02:51 PM   #4
RPOZ11
RPOZ11's Avatar
Coated with stacked tubes before 3" collector :
HO72 build :
2017 SS
Old 04-01-2017, 02:53 PM   #5
camtoys1
there is a part number on the header flange you can look it up on line
camtoys1 is offline   Reply With Quote
Old 04-01-2017, 04:31 PM   #6
RPOZ11
RPOZ11's Avatar
303Y on one set
The one set with the O2 sensor is dated 8/98
The black painted header has a different 2 tube end arrangement prior to the collector.
The black painted one must be an earlier release.
I've noticed that the collector ring is 1 hole down, then 2 holes to the top
HO72 build :
2017 SS
Old 04-02-2017, 05:48 PM   #7
RPOZ11
RPOZ11's Avatar
Here is the black painted one installed with the offset 2 tubes prior to the collector:
HO72 build :
2017 SS
