64-66' Removing front Clip
Hey ya'll was just wondering how hard it was to remove the front clip and everything on these trucks? As well as if anyone has any pics of when they did it or anything, or if i missed a thread of someone walking through it.
Also if you happen to know how to remove it all in one piece? If seen pictures of this but not 100% sure how its done. Thanks. ![]() ![]() Last edited by bbluma; 04-01-2017 at 11:55 PM. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 64-66' Removing front Clip
Take the 4 bolt off each side of inner fenders and firewall. Then the rad support bolt, then there are two bolts that fasten the lower inner fenders to the lower cab, then the bolts to remove at the lower fenders at cab..... I think that's it. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You will have to remove the cowl corners to access the 2 top fender bolts. Then remove the 2 bolts where the inner fender is bolted to the firewall. There is a bolt from the lower inner fender to a cab bracket as well at the lower inside of the outer fender. Then the radiator support bolts at the front. You will also need to remove the little cover where the steering column shaft passes thru the inner fender. Also it is easiest if you remove the front bumper as well.
