Old 04-02-2017, 02:54 PM   #1
dsterley
Tie rod help
So im replacing the upper and lower arms as well as adding drop spindles on my 65. Went with 73-87 components. I picked up new outer tie rods (73) realized the threads were bigger. So since the taper on the center link is smaller than the outer tie rods, whats my best option? Stick with the same size inner tie rod and buy a center link that is the two different size threads? Or is there a inner tie rod with the smaller taper but the same size threads?
dsterley is offline   Reply With Quote
