04-02-2017, 07:03 PM | #1 |
Tail light ground problem?
So I just built a new bracket for mounting my tail lights on my step side. My problem is that now the tail lights don't work. The blinkers and the break lights work fine. They all worked before I mounted using the new bracket. I know that the original brackets served as the ground. In order for the new bracket to ground the electricity now has to travel to a stainless steel bolt that is connected to a aluminum bracket and then through another stainless bolt. Do the problems I am having sound like a ground problem?
04-02-2017, 07:21 PM | #2 |
Re: Tail light ground problem?
Yes.
I had an '80 stepside (similar setup). I would remove the tail light brackets every year to repaint them, and replaced the star washer bolts with stainless bolts. Over time all of the rear lights got funky. It took a while to figure it out but I assumed it was the ground. I ran a separate wire from the bulb socket, through the harness conduit to a clean location on the frame (on both the LH and RH lamp). Worked like a champ after that. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-03-2017, 10:30 AM | #3 |
Thanks that is what I was thinking.
04-03-2017, 11:04 AM | #4 |
The taillights and the brake/directional lights all share the same path to ground so it seems odd that one would work and not the other with a bad ground. Also, what's the chances of both sides only partially not working. Just sayn'.
04-03-2017, 11:15 AM | #5 |
Could it be that I have the two wires switched?
04-03-2017, 01:06 PM | #6 | |
My recommendation would be to ensure a good ground first, and then start chasing any other schematic problems. No ground = unexplainable funkiness. K
04-10-2017, 04:35 PM | #7 |
what the heck happened there
04-12-2017, 10:50 AM | #8 | |
04-13-2017, 12:13 AM | #9 | |
Nothing in the above posts suggest one filament (they share a ground) doing anything other than the other. An 1175 is a 2 filament bulb that share a ground/return. Last edited by franken; 04-13-2017 at 12:19 AM. |
04-13-2017, 12:35 AM | #10 |
From memory, i think tailight circuit is the brown wire. Get under there with a test light and see if there's power on the brown wire with the lights on. Make sure the light is grounded (make it light up with a known good circuit) If yes, then it's a ground, bad bulb or a junk tailight assembly.
Ancient, crappy trailer wires can really mess things up. Get rid of it if not needed. IMHO, as a professional auto electrician, these old trucks have some amazingly durable wiring and components. I hate to think what modern car circuits will look like in 50 years.
Everybody has to believe in something. I believe I'll have another beer. |
04-13-2017, 12:58 PM | #11 |
When there is a bad ground, (or non-existent), the turn signals and brake lights, (same filament) will appear to work. What is happening is the power from the brake switch or turn signals is going through the filament but is seeking a ground through the tail light filament. Both filaments will be in series with each other which results in only the tail light filament illuminating. (It takes less power for it to light.) But it will be slightly dimmer.
05-06-2017, 06:37 PM | #12 |
I think I found my problem. When I turn on my lights and use a test light the only one that didn't light up was the tail light white. I tuck the switch appart I found this. I think the little coil of wire is supposed to connect to the brass circle that the little nub of a wire is sticking out of. Both ends have a little ball on the end.
05-06-2017, 06:40 PM | #13 |
No, that's just the rheostat to dim the instrument cluster lights. Have you tried disconnecting the firewall connector that houses the two blue wires?
05-06-2017, 06:42 PM | #14 |
I tried grounding the lights to the frame and it still didn't work so I went to the switch.
05-06-2017, 06:43 PM | #15 |
BTW, ignore my question. I have two threads going in my head at the moment!
05-06-2017, 06:44 PM | #16 |
It doesn't have one anymore. It is a new painless harness
05-06-2017, 06:46 PM | #17 |
Should there be power coming out of my switch into the tail light wire?
05-06-2017, 06:47 PM | #18 | |
05-06-2017, 06:52 PM | #19 |
05-07-2017, 06:39 PM | #20 |
Ok so there is no voltage at that wire coming out of the switch so I think it is the switch.
05-07-2017, 09:17 PM | #21 |
Did you ever check the fuse? Have to ask. That's the first thing that should be checked.
05-07-2017, 09:39 PM | #22 |
05-07-2017, 09:44 PM | #23 |
I tried to check the fusses but it is a painless block and I didn't see one specifically for tail lights
05-07-2017, 10:23 PM | #24 |
Definitely find it. That could be the problem.
05-13-2017, 08:38 PM | #25 |
Checked all my fuses and they are all fine. I think it is the headlight switch sense I am getting power from all the wires going into it except for the tail light wire.
