Ps pump pulley
Hey guys I'm New to this and hoping to find the help I need.
I have a 72 c10. I bought a 283 sbc for it and I ran into trouble with the power steering pump pulley not lining up with everything else. (The pump is off a 70 c10 350 I believe). I've asked around and no-one seems to know. I'm wondering if it's the pulley I need or a different bracket. Any advice is appreciated! |
![]() ![]() Join Date: Oct 2014
Re: Ps pump pulley
Do you have a short or long water pump? I think that's what you base you pulley choice on.
Re: Ps pump pulley
It is a short water pump. I wonder if the brackets I have are for a long water pump maybe
Re: Ps pump pulley
I had the same problem when I installed the Brothers power steering kit on my 70c10 I ended up shimming out the crankshaft and water pump pulleys no pics yet but I can get some. I left the alternator on the left side where it was originally so I wouldn't have to change the wiring harness. I live just down the road from Jegs and they had them in stock also Summit sells them good luck!
Re: Ps pump pulley
Mine sits there, but I have a factory 4 rib crank pulley. Power steering is the 3rd one from the block on mine.
Re: Ps pump pulley
I was going to say the same thing - I have a 350, but my power steering sits right where yours is, from the appearance. I have an additional pulley past the two you have which connects the power steering.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
![]() Join Date: Jul 2016
Re: Ps pump pulley
Power steering sits on the 3rd row of the crank pulley, factory its a separate pulley and keys to the inner pulley, it wont work with that aluminum pulley you have now.
The 3rd row is also a little further out than 1st and 2nd row separation, 1/8" or so. |
Re: Ps pump pulley
The shaft on your pump looks long. Is there a way you could mount the pulley closer to the pump? Another option is to find a three groove lower pulley so that it will line up with your pump.
Re: Ps pump pulley
Thanks for the help! I'm gonna try a 3 groove pulley
Re: Ps pump pulley
The 1970 has the old style pump with a nut holding the pulley on. The newer ones are just pressed on.
Just thought this info might be helpful. |
Re: Ps pump pulley
your crank pulley is one short
