Crossmember swap help
So, I've been trying to swap a 63 crossmember on to my 62 and I hit a bit of a problem and need some help.
I have been reading dozens of threads on the topic, including the most commonly referenced one, http://67-72chevytrucks.com/vboard/s...d.php?t=366850, and I still cant figure out if I'm lining things up correctly. I wasnt able to take any wheel base measurements from the old crossmember, but I was hoping I could get 1-2 of the original holes to line up so to hold it in place. From there I was just going to drill out the holes where they sat. Right now I have the center bolt in the inside of the frame aligned, it also looks like the forward most hole would also align there. You can see it in the first picture. on the outside of the frame I was expecting another hole to be lined up from what I had read, but this doesnt appear to be the case. It actually looks like I could move the crossmember back a bit and the two top holes would line up. This is the same on both sides, so everything seems to be straight. My question is, which hole should I have lined up before I start my drilling? Thanks for the help. ![]() ![]() |
Re: Crossmember swap help
Do you have a std trans w/ the stock rear cross member / engine mount in your truck?
If you do I could measure from the front cross member to the rear one on my parts '66 for you. |
#3 | |
There has to be someone out there that has swapped these cross members before. Posted via Mobile Device |
Welp. It's a SWB, I think that means I should have a 115" WB. I'll measure that out and see where it gets me.
![]() Join Date: Jul 2014
I put an 72 cross member in my 62. The upper two holes on each side of the cross member L-bracket are the ones I used to properly locate the cross member to the 62 frame. You show these holes in your second photo. I then had to drill new holes, or slot existing ones, for the rest of the bolts. A 63 cross member should attach the same way.
Also keep in mind that the large bolt holes coming up through the bottom of the frame are spaced evenly front to back 63 and later vs the 62, shown in this thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583, post number 9. On the 62 the rear hole is closer to the center hole.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
#6 | |
