![]() Join Date: Feb 2015
61 apache 3 speed transmission help needed
It sometimes grinds when going from first to second and recently i can hear a whining noise when i floor it (in 2nd or 3rd). i wonder if my gear box fluid is low. do you know how i can check it and fill it?
Re: 61 apache 3 speed transmission help needed
On the side of the trans there is a fill plug around midway up the trans. take it out and stick your finger in the hole. if no oil on your finger it's low. add oil till it runs out of the hole. I would drain it (remove the plug from the bottom of the trans) and put new oil is it as it's old anyway. Use any reg 80/90 weight gear lube.
1961 chevy K10 my build is------------61K10 build |
Got it- thanks a lot.
Scott |
