Old 10-19-2003, 04:13 AM   #1
apstguy
LED King
apstguy's Avatar
LED bulbs for dash
Call me the LED king. I just installed LED bulbs in my dash including all the "warning" lights (Check engine, brake,choke,highbeams) I found a place that sells them for cheap. I like it so far. It is a little dimmer than before, but I am installing white face overlays only. I installed a blue one in my Heater/AC controls. It looks cool! I need to do some juggling around and order other ones since I ordered 2 of every type of bulb, leaving my with odd buls in odd places. Like a green one in my tach. I put green LEDs in place of my turn signal indicators and like it much better.
Problems:
I cracked almost all the mounting tabs off the cluster. I knew it was going to happen....
My temp. gauge has stopped working. Probably just a loose connector???
My voltmeter now reads slightly more that it used to (1-1.5 volts). Why would this happen?? Weird.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 10-19-2003, 04:14 AM   #2
apstguy
LED King
apstguy's Avatar
If you want the site for the LED bulbs, PM me. It is a tad bit confusing as they don't have the bulbs under the names you think they would. I have catolog #s that make it 200% easier.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 10-19-2003, 09:51 AM   #3
Chevy67Tk
Chevy67Tk's Avatar
Re: LED bulbs for dash
Originally posted by apstguy
Problems:
#1. You have to brake a few eggs to make a cake.
Corny but what im trying to sat is some times you have to mess something up to end up with something better
#2. You’re probably right
#3. The close proximity of the old incandescent bulbs my have had an Electro magnetic effect on the gauge that L.E.D. don’t have. I know this ones a stretch but hey it’s possible.
Any ways it sounds like you’re on the right track and when you get a chance send me a PM on were to find the bulbs.
Dan
Chevy67Tk is offline   Reply With Quote
Old 10-19-2003, 04:52 PM   #4
bigd65
bigd65's Avatar
so if they are slightly dimmer, why would you keep them on there. i used blue covered bulbs once. they were dimmer. after about a month, i pulled them and put all new white bulbs
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 10-19-2003, 04:54 PM   #5
Russell
Professional Grade
Russell's Avatar
I would guess that not having inefficient filimant bulbs probally saves some energy... I know that on ever bass hit my electrical guage falls :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-19-2003, 07:13 PM   #6
crackajacka
Stylin
crackajacka's Avatar
i had to goto a 100 amp alternator to fix that problem and i have a optima yellow top battery also the whole stupid voltage gauge needle bouncing only happens when ive got the turn signals on lol
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-20-2003, 12:48 PM   #7
apstguy
LED King
apstguy's Avatar
Jeff - I'm going to put the white face overlays on then it won't matter. I don't drive much at night anyways.
Today the temp gauge started to work, then next time I looked it was dead again. Loose wire! I'll need to look into that.
The voltmeter thing still eludes me, but if the power is routed through the circuuit board and a light before it gets to it, it could cause the sudden increase in volts to the gauge.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 10-20-2003, 06:20 PM   #8
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Can you use LEDs on a rheostat? What happens if you dim the dash lights with LEDs in there?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-20-2003, 08:50 PM   #9
Blue Beard
Blue Beard's Avatar
Pm'd you on the lights........Thanks,
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-21-2003, 01:10 AM   #10
apstguy
LED King
apstguy's Avatar
I'm going to try the LEDs with a pot. The LEDs don't change much when you turn the dimmer in the truck.
I got them from www.digikey.com you can also get them from mouser Electronics at www.mouser.com
These part numbers refer to digikey. These are listed under "based LEDs" - "LED miniature wedge base"
There are two types. "Milky" or "water clear" - you will want the milky. The water clear are -brighter- but focas it in one direction. The milky ones look much more like bulbs in light dispersion. All part numbers refer to milky diffused.
White: milky diffused - 441-1008-ND - $1.60
Blue: 441-1006-ND - $1.50
Green: 441-1000-ND - $1.60
Yellow (orangish amber): 441-1002-ND - $.99
Red: 441-1004-ND - $.99
Use the red and yellow for the warning & indicator lights. Use the green for the turn signals. Use a blue for the brights indicator and possible the Heater/AC controls. Use white for the gauge lighting and possibly Heater/AC controls. If you live in CA, don't forget the extra check engine light when you order. It looks orange (like the 4X4, glow plugs,& choke), but the yellow LED matches exactly.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 10-21-2003, 08:50 AM   #11
Blue Beard
Blue Beard's Avatar
Thanks for the links......
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 10-21-2003, 12:18 PM   #12
87Silvy
87Silvy's Avatar
I had some superwhite bulbs behind the four smaller gauges on the left side, looked pretty good, gave them a nice tint. Don't feel like spending $4.00 for 2 bulbs.
1987 Chevrolet Silverado
2005 Chevrolet Silverado
87Silvy is offline   Reply With Quote
Old 10-22-2003, 11:31 PM   #13
apstguy
LED King
apstguy's Avatar
ttt - kicking this up for anyone else interested...
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
