Old 04-04-2017, 07:10 AM   #1
notsolo
notsolo's Avatar
72 Custom Dash Bezel
Built a glove box door custom dash bezel for my 72 blazer, most of the parts out of a 93 Caprice wagon. Whole drive train is out of the same car. I have most of the gauges working ....Posted on the Electrical forum with no response .... Trying to get the electronic speedometer working, 1993 5.7L TBI 4L60 with vss wiring... I wired the A10 from the ECM to the back of the speedo, did not realize that it needs the buffer module. I hope this is what it needs.. 7 wires on the buffer, pink power, black ground. (F) Brown input from A10.. 2k... (C)Green output to back of speedo 4k? My module is different of coarse (C) is another brown wire.... Are the yellow and purple wires needed? Thanks in advance...Ed
notsolo is offline   Reply With Quote
Old 04-04-2017, 11:49 AM   #2
DBK81
DBK81's Avatar
Re: 72 Custom Dash Bezel
Did you have the factory gauges and bezel to begin with?
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 04-04-2017, 12:17 PM   #3
notsolo
notsolo's Avatar
Yep on both. Different trans and rear axle now in the Blazer, I hope to get the Caprice dash speedo working, with this gear ratio. Other wise it's back to the 1st bezel and find trans output with cable and different gears.
Old 04-04-2017, 01:26 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 Custom Dash Bezel
I suggest you go to the LS section and talk to ls1nova71 are PM him. He has done a lot of electric conversion stuff and even cruise control for my 6.0.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-04-2017, 01:44 PM   #5
notsolo
notsolo's Avatar
Thanks Andy, I did PM him a month or so ago, before I found out I needed this module to make it work. I was hoping somebody here would know. I will be asking him next...Ed
Old 04-04-2017, 02:27 PM   #6
Andy4639
Old member
Andy4639's Avatar
I wished I could tell you. That is one area I have no idea on anything. Hope you get it straightened out. That's a cool mod. I like it. Retro looking but modern!
Old 04-04-2017, 06:47 PM   #7
clay68c10
clay68c10's Avatar
You could search or post up on thirdgen.org or gearhead-efi.com. Those folks have some good tricks for DRAC modules.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-04-2017, 07:56 PM   #8
notsolo
notsolo's Avatar
Thanks, did Gearhead and CK5, got a few idea's still missing key wiring output color. Jags that run.com was one I never heard of, they have some good information too.
Old 04-04-2017, 08:07 PM   #9
roboticjunky
Here's a VSS Buffer/ DRAC out of a truck. It sounds like the one you might have.
roboticjunky is offline   Reply With Quote
Old 04-04-2017, 09:03 PM   #10
notsolo
notsolo's Avatar
Should have post photo of mine, 1st ...A C D F H.....A is black w/white stripe ground wire ...H is pink w/ black stripe 12v ...I think F brown wire is 2k input from ecm...other brown wire C..? or green wire D is 4k output that I hope will make this work. And I am unclear about yellow and purple wires!...Thanks for chiming in, I think the truck Drac module and wiring are different.
Old 04-05-2017, 08:33 AM   #11
roboticjunky
The yellow and purple go to the VSS. Then the signal goes through the buffer. A is ground, H is 12v power, D goes to speedo for input, and F probably goes to the PCM for speed input.
C is problably for cruise control, which doesn't have to be hooked up.
Old 04-05-2017, 08:53 AM   #12
Bigdav160
Bigdav160's Avatar
This is the diagram for your application. It seems you drac is from another application.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-05-2017, 09:57 AM   #13
notsolo
notsolo's Avatar
Thank you, Bigdav160 Also roboticjunky....That is it, wow...Looks like C or D could be used for 4k pulse... I started to make extention wires for the yellow and purple wires, I guess I will splice into the wires near the trans, Howell TBI Harness wires run to ecm, but probably are for idle control etc when coming to a stop. I am going to print a copy of that schematic and put it under my pillow. Maybe something will soak in...
Old 04-05-2017, 10:05 AM   #14
clay68c10
clay68c10's Avatar
Definitely add the vss signal wire to your tbi ecu. It uses that signal for a lot of things, idle air control motor is the main one you will notice, but there's a lot of other functions that are speed dependent.
13 Tahoe LTZ
