04-04-2017, 11:52 PM | #1 |
Power steering pump mounting bracket?
I recently acquired a complete power steering set up, to include the gearbox, hoses and pump, from a 71 C-10.
The one item I didn't get is the bracket that bolts the pump to the engine, and has the adjuster on it. Is there a certain type of bracket I need? The one I have on my truck is cast iron, but I've been unable to find another like it for this spare unit. Can just get a bracket off another SBC to work correctly? And will I need the '71 center link for the steering to work right, if I put it on a truck from 67-70? I can get it, so it's not a problem. |
04-05-2017, 10:39 AM | #2 |
Re: Power steering pump mounting bracket?
Any thoughts? Should I post this in a different forum?
04-05-2017, 11:58 AM | #3 |
I would think it is the pitman arm that you need to change, but I'm not too familiar with these swaps as mine have had PS already.
I would wager that as long as you get the mounting bracket off a short water pump bracket set with factory PS it would work just dandy.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
04-05-2017, 12:26 PM | #4 |
Old member
The bracket is a two piece metal. One goes around the pump with bolt hole to mount it to the bottom of the engine. The second part mounts to the side of the engine on the motor mounts.
My old motor in the 71. The two holes on bottom right are for the pump mount.
04-05-2017, 03:12 PM | #5 |
Thanks Andy. Now I can find what I'll need, to put PS in a truck that I don't have yet. Charlotte this weekend!
04-05-2017, 07:09 PM | #6 |
Old member
04-05-2017, 09:30 PM | #7 |
Center link not needed for power steering, just when going from drum to disc
