04-07-2017, 07:47 AM | #1 |
Speedometer cable bracket
I am replacing the speedometer cable in my truck and on the old cable there was a bracket around the outside of the cable, but it was just hanging there.
Does anyone know where this bracket should be attached to. It has one hole for a bolt or nut in it. It is the angled bracket like what is shown in this picture.
Gary Slowly looking for my next 67-72 truck |
04-07-2017, 08:42 AM | #2 |
Re: Speedometer cable bracket
My truck has a stud in the firewall the bracket is attached to. I can take a closer look at it later today if you can't find it.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
04-07-2017, 08:44 AM | #3 |
Sounds good, I will take a look tonight after work. Where is it in relation to the brake booster?
04-07-2017, 09:15 AM | #4 |
The stud is directly below the steering column, on a metal bracket about 5 inches down.
04-07-2017, 11:12 AM | #5 |
04-07-2017, 11:16 AM | #6 |
My bad , where the wire harness is in this pic . You can see the stud below steering colume.
Posted via Mobile Device |
04-07-2017, 12:45 PM | #7 |
This may help.
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
