Old 04-07-2017, 09:24 PM   #1
HO455
Post Whore
HO455's Avatar
Question Searching for factory hood hinges. Need help!
I'm looking for some factory hood hinges to have sent out and rebuilt. My current ones are repops and one of the rivets is looking like it is going to fail. My question is how to tell original from repops? Everything I have read makes me want to avoid the GM ones from the later 80's and newer. Do the originals have anything stamped on them?
As always thanks in advance.
RIP Bob Parks.
Old 04-07-2017, 10:03 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Searching for factory hood hinges. Need help!
Coincidentally, today was "hinge day". Pulled my springs off, and I'm ready to send NOS springs with my original hinges off to Willie at http://www.hoodhingerepair.com
I figure to have him finish coat these the Eastwood phosphate he's using.
GM later than 80s no good huh? Interesting. Anyway, here's your info.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-07-2017, 10:47 PM   #3
71CHEVYSHORTBED402
BTW, just because my original hinges have the markings cited doesn't mean they all did. May have varied based on vendor, etc. From what I've seen however, all the original hinges had the rivets in the pic.
Tony
Old 04-08-2017, 08:58 PM   #4
HO455
Post Whore
HO455's Avatar
Thanks for the information. Now I have some knowledge I'm sure I will be dangerous.
RIP Bob Parks.
Old 04-08-2017, 10:20 PM   #5
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Last week I reinstalled my hood after Willie ( like in post #2 ) http://www.hoodhingerepair.com redid my hinges. I also had a new cowl to hood seal installed and I know sometimes when you install the new cowl seals they will hold the back of the hood up for a while. With the rebuilt hinges down it went like it should. Get a set of originals rebuilt and you will be very satisfied.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-08-2017, 10:37 PM   #6
Lanman1972
Lanman1972's Avatar
Not sure if it helps, but Manes Truck Parts sells good used hinges.
Lanman1972 is offline   Reply With Quote
Old 06-04-2017, 11:24 PM   #7
Already Gone
If your still looking I have a set. They are from a parted truck and were in a parts lot I bought.
Old 06-05-2017, 05:52 AM   #8
randy.powell
Like others have mentioned, go with Willie. I had him restore mine a couple of months ago. Beautiful work and well worth the investment.
B/R,
Randy
randy.powell is offline   Reply With Quote
