67 ignition switch and bezel install
I've decided to redo the wiring on my truck due to the horrible job the previous owner did. While I'm doing so I decided to redo the ignition. The previous owner installed a tilt column from a later model which meant that the ignition was no longer on the dash. He instead installed a push button in its place. I ordered a whole new setup from LMC with all the correct year model parts. The switch, the spacer, the cylinder, and the bezel. When I went to mock it up I noticed that the distance from the spacer to the bezel was too far, meaning the bezel wouldn't reach the spacer and switch. Now my truck is a 67 and the bezel I ordered shows to be the correct one for 67. The dash hasn't been altered where the ignition was originally. And ideas outside of ordering the 68-72 bezel and seeing if it corrects the issue? If pics are needed for any clarification I can provide.
William
William |
#2 | |
The Older Generation
Re: 67 ignition switch and bezel install
The small chrome bezel and small spacer are '67 only. The bezel is reproduced but the spacer is not. You probably have a spacer for the '68-'72 trucks. The first picture shows the '67 only parts and the second picture shows the '68-'72 parts. The '67 spacer can be hard to locate. LockDoc
It turns out I do have the spacer for a 68-72.
William |
#4 | |
![]() LockDoc
Post Whore
![]() Join Date: Feb 2016
They're not the only ones. I noticed several vendors at the Portland swap meet with parts labeled that way. You would think that people who only sold Chevy truck parts would know these things.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
