Old 04-08-2017, 01:08 AM   #1
l79m20
custom steering wheel
Recently aquired a nice 1963 chrome based custom steering wheel which I want to use onmy 1966 1/2 ton. Does anyone know what the best paint to restore this wheel is , I need medium fawn , an epoxy paint would be recommended? I only want to fix this once. Your thoughts?
l79m20 is offline   Reply With Quote
Old 04-08-2017, 10:42 AM   #2
63burban
Chevy addict
Re: custom steering wheel
I used Fawn base/clear, been holding up for years
63burban is offline   Reply With Quote
Old 04-08-2017, 03:14 PM   #3
l79m20
was the fawn base an enamel or epoxy based?
Old 04-08-2017, 07:38 PM   #4
fleetman
Where can one get the fawn paint ?
fleetman is offline   Reply With Quote
Old 04-09-2017, 10:06 AM   #5
63burban
Chevy addict
Base coat clear coat was applied by a body shop and I had the color matched to the inside of my ash tray cover. I would have to look but I think it matched a Nissan color.
Old 04-09-2017, 08:00 PM   #6
l79m20
Thanks i'll try to find a matching paint.
Old 04-09-2017, 09:24 PM   #7
Clif Dzzzz
Hey.....I went to an Auto Paint Jobber......took the ash tray cover and they scanned it and matched it pretty close.....about $ 27.00 / Rattle can......its worth the price for small projects......then clear coat
Clif Dzzzz is offline   Reply With Quote
Old 04-13-2017, 01:23 PM   #8
damnyankee36
damnyankee36's Avatar
I got my interior paint through a company I can't think of at the moment. It's lacquer. The Dark (Or is it medium?) Fawn for the dash is a flat velvety finish to it. The medium, (Or light) Fawn for the rest of the cab is regular flat.
I haven't painted it yet but I plan on using the lighter fawn for the steering wheel and buff it out. Auto paint forums have suggested using urethane reducer instead of the lacquer thinner to get a gloss without buffing. Not sure of the mix ratios, however. Using a slow lacquer thinner is supposed to also help with the gloss.
When I get home I will try to remember to post the company and part #'s.
damnyankee36 is offline   Reply With Quote
Old 04-13-2017, 06:47 PM   #9
damnyankee36
Here's that info:
I got my paint from TCP Global. The Dark Fawn is #22743 FAWN POLY (SUEDE) for the dash. The Medium Fawn is #22151 MEDIUM FAWN POLY for the rest of the cab and steering column/wheel.
