Old 04-08-2017, 08:50 AM   #1
HunterRotten
HunterRotten's Avatar
Fiberglass fenders?
I stumbled upon an ad here locally a few days ago and my dad and I went out there yesterday. No title truck that was a mix of random parts. The guy was going to send it to the scrap yard and was basically giving things away. I came for the front fenders and left with an interior kit, GMC cab trim, radiator support, bumper (bumper guards!!), and of course some fiberglass front fenders.
I've not got a clue how this truck got fiberglass fenders, it was a rusty turd. It had a steel hood on it previously and I'm wondering if that's such a good idea?? They seemed to hold up okay. I don't see any stress but again the truck was ROUGH.
Does anyone know where you can even get a set, and should I use them? The body shop has to try to fit a set of steel Chinese fenders anyway..
HunterRotten is offline   Reply With Quote
Old 04-08-2017, 08:51 AM   #2
HunterRotten
Re: Fiberglass fenders?
I'll get some better photos this afternoon, here's a picture of the parts donor.
Old 04-08-2017, 09:08 PM   #3
andyh1956
I've no experience with Chevy truck fenders, but on Jeeps when moisture makes it to the steel supports fiberglassed into the fender, then they rust & swell the fiberglass. No way to fix it then.
I woulda had to drag the whole truck home & make a trl outta the bed & frame!
andyh1956 is offline   Reply With Quote
Old 04-08-2017, 09:43 PM   #4
HunterRotten
He had plans for the front crossmember and the rear differential for his 67 truck. Bed was gone when I got there.
These fenders are pretty rough and weren't taken care of, there's some wrinkles in it and they are separating. I think they are savable and I think I would prefer them over aftermarket fenders from overseas.. I just hope the body shop agrees but I have a feeling they won't.
I didn't think about the supports rusting and swelling..
Old 04-09-2017, 12:30 AM   #5
Pontiac1976
Pontiac1976's Avatar
Some 73-80 -Suburban & 3+3 got them, But mostly Duallys got the fiberglassed finders It was to lighten up the truck a little.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-09-2017, 09:09 AM   #6
TKCR
TKCR's Avatar
Did you happen to snag that seat?
Old 04-09-2017, 01:23 PM   #7
HunterRotten
I did not take the seat, I knew you would ask. If he still has it, it's on my local craigslist and is in Clay City, KY. He's not too fond of holding parts though. It's first come first serve.
Old 04-09-2017, 07:27 PM   #8
TKCR
TKCR's Avatar
Thanks for the info, I'll look it up. I'm still planning on coming down.
Old 04-10-2017, 08:29 AM   #9
Keith Seymore
Keith Seymore's Avatar
Negative. There were no fiberglass front fenders from the factory.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
