Old 10-19-2003, 05:12 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
Question access into shift lever housing ?
I am stuck at the turn signal switch mechanism and can not get it out...what must I do to get past it?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 10-19-2003, 07:04 PM   #2
jef5150
Inline 69
jef5150's Avatar
pic,,,,,,,,,,
remove turn signal lever screw (#37),remove 3 screws that hold signal assembly(#32),"PUSH" in "hazard warning" then un-screw it,let me know if you need more info,,,make sure you push hazard in or cover wont slide over it,,,jeff
jef5150 is offline   Reply With Quote
Old 10-19-2003, 07:07 PM   #3
JimKshortstep4x4
Talking
The wires can hold it in. I assume that you removed the lever, the three hold down screws and have pushed the emergency flasher button in. After that you have to have the wire shield out of the way, the wires unplugged and then the switch should come out.
Jim
Old 10-19-2003, 10:43 PM   #4
sactoC10
71 DELUX
sactoC10's Avatar
Smile
Thanks for the illustration. Every bit of info helps. It ended up being the wiring harness that was hanging me up. Figured out the twist thing once it was all loose...and was able to solve my problem.
THANKS!!!
2003 FORD Escape
1998 Honda VTR1000
