04-09-2017, 04:05 PM | #1 |
Frame question
I've looked for frame pictures but really couldn't find any to help me. Behind the main front crossmember of my truck there is a smaller cross member, and then the transmission crossmember for my automatic. Is that middle member something that was there since it was as originally a four speed truck? With it there I can see why the PO omitted the trans dust cover I'm trying to refit. Thanks.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
04-09-2017, 04:17 PM | #2 |
Re: Frame question
Pictures would help, but my question would be----how did you install an auto with the 4 speed x-member in the way.
04-09-2017, 04:33 PM | #3 |
Re: Frame question
The PO did and it fit perfectly. The middle member has no part
Of the engine or trans mounted to it. Everything clears and it's riveted to the frame like it belonged for some reason.
04-09-2017, 05:51 PM | #4 |
Re: Frame question
No pics but I will jack it up this week and try for some.
04-09-2017, 09:11 PM | #5 |
Re: Frame question
Here are a few pics. The main engine mount cross member
04-09-2017, 09:12 PM | #6 |
Re: Frame question
Transmission crossmember under the cab
04-09-2017, 09:15 PM | #7 |
Re: Frame question
And the third crossmember in between I'm curious about. It has a square shaped hole on each side that must have had mounts in them
04-09-2017, 10:31 PM | #8 |
Re: Frame question
I'll probably someday grind the rivets and smash it out. The PO took a lot of shortcuts
04-10-2017, 12:44 AM | #9 |
Re: Frame question
I can only imagine
