Old 04-10-2017, 12:49 PM   #1
cajundragger
Making a single tank '79 bed, a dual '76
Hi All,
This weekend I picked up a 'parts' truck that is a complete shortbed '79. It's a single passenger tank, with a fuel door(as was standard in '79 from what I can tell).
I want the bed to swap on my '76 C20 custom deluxe CCLB. I'm trying to build more or less a factory short bed, as it would have come in '76.
The goal is to keep dual tanks, and swap my long bed tanks for shortbed tanks. I want to keep the fuel caps, and loose the fuel door that is currently on the bed.
My questions-
  • the easiest way to repair the passenger side of the bed is to put a bedside on it. I figure I can buy a round fuel fill bedside panel for 73-78 trucks. This would fix my dents and give me the correct fuel filler on the passenger side.
  • the drivers bedside is in good shape. No need for a full bedside change. Is adding the fuel filler as simple as getting a patch with the filler I want and putting it in the bedside? What about the inside bed pieces that support the filler? The floor is already notched for a filler... Doesn't anyone know of a supplier for just the filler opening in the bedside or do I need another donor bed to chop it out of?
  • I'm going to swap the hardware on the tailgate to the earlier first style. Is there anything else I need to do to make the '79 bed precisely a '76 bed?
  • Can I use my stock long bed fuel filler tubes? I'm not trying to cut up my current long bed as it's in good condition, but I can rob all the bolt on parts off it...
I appreciate any info you guys have. Thanks.
cajundragger is offline   Reply With Quote
Old 04-11-2017, 12:06 AM   #2
KrazyRay
KrazyRay's Avatar
Re: Making a single tank '79 bed, a dual '76
All filler necks are the same 73-78, but some have larger diameter openings. Yours should work fine. I have filler patch panels in stock if you need one. There are no extra supports or brackets for 73-78 filler necks. They use 3 screws at the bed side and the hose holds the bottom end in place.
KrazyRay is offline   Reply With Quote
Old 04-11-2017, 02:56 PM   #3
cajundragger
are you listed on ebay? I may have messaged you. My user there is radustin.
