Old 04-10-2017, 04:28 PM   #1
cooperhw
cooperhw's Avatar
big block stock suspension
I was wondering if anyone out there has a 73-87 truck with a big block and stock suspension/tires/etc. could do me a favor and measure from the ground up to the bottom of the pinch welds on your cab. Mine did not have a motor/trans in it when I got it and just wondering how much room do I have before it hits the pavement?
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-10-2017, 07:06 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: big block stock suspension
The control arms will hit the ground long before the pinch will.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-10-2017, 08:45 PM   #3
cooperhw
cooperhw's Avatar
Well, thanks, but that doesn't answer my question. If anyone "actually " has the answer to my question I would appreciate it.
Later,
Wayne
Old 04-12-2017, 01:53 PM   #4
GRADYS Performance
GRADYS Performance's Avatar
I have a Stock 1985 C20 Silverado 454 Suburban. Where would you like measurements taken from. Not sure what you mean by Pinch welds.
GRADYS Performance is offline   Reply With Quote
Old 04-12-2017, 01:58 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Educated guess, 13.5 inches the hub cap is typically centered on the pinch and a 27'' tire.
I've never had a stock one long enough to measure.
Old 06-21-2017, 10:23 AM   #6
cooperhw
cooperhw's Avatar
Thanks Grady. Sorry it took so long for me to respond. I have moved way past that point on my build now, so it's irrelevant. Thanks anyways.
thanks. I mainly needed to know how much the bottom of the cab "drooped" over the front cab mount and whether or not I needed to trim the bottom of it off. Anyhow, I trimmed mine off and now the rockers (not bottom of pinch weld) sit on the ground.
Later,
Wayne
