Old 04-10-2017, 07:37 PM   #1
cheepin
QJet Carb# questions
Have a QJET carb on a 350 that has the numbers 17054930. Trying to find a rebuild kit for it and what CFM it is. Not finding this number. TIA.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 04-10-2017, 07:44 PM   #2
Jake Wade
Jake Wade's Avatar
Re: QJet Carb# questions
I think you need to get a better look at the number.
Jake Wade is offline   Reply With Quote
Old 04-10-2017, 07:45 PM   #3
Bandit130
Bandit130's Avatar
http://www.carburetion.com/CarbNumbe...umber=17054930
http://www.ebay.com/itm/Rochester-Qu...lWr7ty&vxp=mtr
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 04-10-2017, 07:49 PM   #4
Jake Wade
Jake Wade's Avatar
http://www.crankshaftcoalition.com/w...n_and_decoding
Old 04-10-2017, 08:35 PM   #5
cheepin
Nope that's the numbers. Date code is 0958. That's the thing your link and Bandit130"s link are contradictory. Best I found is the 17054930 is a replacement carb of some sorts. Even that rebuild kit's numbers vary. In the first list it's there. But not in the second. May have to give that guy a call.
Edit. Did find the number in the second list. doah. What CFM would this be? 650?
Old 04-10-2017, 08:53 PM   #6
Jake Wade
Jake Wade's Avatar
What is odd is Q-jets beginning with 1 should be from 1975-on. That 4 is suppose to indicate the year(1974), which is weird.
Old 04-10-2017, 09:44 PM   #7
geezer#99
geezer#99's Avatar
Generally there were two cfm's.
725 and 800.
Some say they were 750 and 850.
But what's a few cfm here and there!
Old 04-12-2017, 07:05 PM   #8
El Dorado Jim
http://cliffshighperformance.com/simplemachinesforum/ cliff ruggles is supposed to be the q-jet guru, contact them and they can help, you can buy his q-jet rebuild book on amazon, covers everything on q-jets, identification and rebuilding https://www.amazon.com/Rebuild-Modif...MH5QA40FH8G2KX
El Dorado Jim is offline   Reply With Quote
