04-11-2017, 10:28 AM | #1 |
Very Hard & High Brake Pedal
1969 C10 Fleetside Long Bed
350 SBC Manual Drum all 4 wheels. New M/C (Bench Bled), new wheel cylinders x4, new hardware and shoes x4, new front rubber brake hoses x2. So here goes, i recently dove back into my truck to get it road worthy again. That meant replacing all the items listed above. After spending about an hour bleeding all the new wheel cylinders (What a PITA), the friend of mine that was helping (also a c10 owner) noticed the brake pedal sat much higher in my truck than his and that the pedal was much MUCH harder to depress than his. This is my first and only manual brake vehicle. So i didnt know any better about how it was suppose to feel. His is also manual brakes. I did notice my brake pedal sit much higher and i did notice after driving his truck that i didnt have to pick up my leg to depress his brakes. I took a look at the M/C rod and theres about 3 threads left to pull the pedal towards the fire wall, his has quite a few more threads. Also when bleeding the brakes, we had to really press hard on the brake pedal to get any fluid moving to the back wheel cylinders. I eventually got a steady stream of brake fluid to all 4 wheel cylinders. We were suspicious that the issue was in the M/C and/or the distribution block. So we individually cracked each line and bled them from the top. Everything seemed to work the way it was suppose to, no air in anything, what could be causing the pedal to be press so hard to get alittle bit of fluid to the rear cylinders, it felt as if the rear wasnt getting enough pressure. It would just trickle out, not blast out. |
04-11-2017, 11:05 AM | #2 | |
The Older Generation
Re: Very Hard & High Brake Pedal
LockDoc
04-11-2017, 11:16 AM | #3 |
04-11-2017, 11:21 AM | #4 |
Great minds think alike...... Let us know if that cures it or not. LockDoc
04-11-2017, 11:22 AM | #5 |
04-11-2017, 12:00 PM | #6 | |
Heat on the fittings help too, even from a propane torch, and it won't hurt anything. Just be careful of the Acetone and if you have a wood floor bed.... LockDoc
04-11-2017, 12:49 PM | #7 |
It's possible you have a M/C for power brakes, sometimes the depth of the push rod hole is different between power & non assist M/C's.
04-11-2017, 12:58 PM | #8 |
04-11-2017, 01:00 PM | #9 |
04-12-2017, 10:25 AM | #10 |
Sorry, the way I read it you had manual (non-power assist) brakes. So it does have a brake booster?
You can put a manual M/C on a booster & vice-versa & it may work. It is probably best to stick with the correct M/C. With power assist (booster) it is common for the M/C to have a larger bore (for discs also). |
04-12-2017, 12:04 PM | #11 | |
