Old 04-11-2017, 05:55 PM   #1
1968vetL-71
Junior Member
1968vetL-71's Avatar
91 guage cluster ?
So the last 3 4l80/205 setups I've parted out or acquired had the guage clusters still in the trucks or came with the parts. What was odd is all 3 of them didn't have the O.D. in front of Drive on the PRNDLL indicator. Now 2 of my previous 91 crew cabs had the 4l80 and had the O.D. indicated in front of drive. 1 was 2wd. Was it a 2wd vs 4wd thing? surely not? were they early vehicles and used the standard Prndll with the electronic speedo? I'm about to purchase another 91 V3500 srw and it has the standard PRNDLL in it??
Any one with some CONCRETE info would you please elaborate. I know there are a few 91 V3500's on here. Thanks as always.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 04-11-2017, 09:13 PM   #2
Brennan
Re: 91 guage cluster ?
Owned 2 91 v3500s so far, both have the OD position marked on the indicator. I'd have to check, but I believe even the cluster I purchased from you has the OD spot. (I'm sure most already know this, but it takes about a minute to swap the indicator from d to an OD one)
Brennan is offline   Reply With Quote
Old 04-11-2017, 09:49 PM   #3
1968vetL-71
Junior Member
The last cluster I sold didn't have the OD on it. It was from a 91 V3500 electronic speedo.
I hear ya on the prndll swap. Why would someone swap it out? especially on the last few I've had and the one i'm about too purchase?
Did the 90-91 blazer/suburbans with the NP241c use any th350 or th400 by chance? Those would of utilized the electronic speedo cluster with no OD in the lineup. That's why I was curious if some early units used these clusters without the OD?
Things that make ya go
Old 04-11-2017, 11:20 PM   #4
1968vetL-71
Junior Member
LOL I just ran across another 91 V3500 Dually with 83,xxx original miles untouched and it has no OD on the prndll??? Pretty odd i'd say. I just can't see that many clusters swapped out on just the ones I find. hahahaha
Old 04-12-2017, 07:51 PM   #5
Half Assed
Half Assed's Avatar
you crawled underneath to verify it has a 4L80?
Half Assed is offline   Reply With Quote
Old 04-12-2017, 09:59 PM   #6
1968vetL-71
Junior Member
The one i'm getting .. yes. Thats the obvious! I'll chalk it up to I'm lucky in finding over 5 V3500's with the indicators swapped out.
Old 04-12-2017, 10:06 PM   #7
GRADYS Performance
GRADYS Performance's Avatar
TH350C transmission was last used in 1986 TH350 was last used in 1980. TH400 was used up till 1990 or 1991 and was replaced by 4L80E. There may have been some overlap on the 400/4L80E. The 4L80E started in 1991.
GRADYS Performance is offline   Reply With Quote
Old 04-14-2017, 10:26 PM   #8
v30crewcab
v30crewcab's Avatar
probably just grabbed what was in the parts bin. why are you parting out crewcabs? must be really rusty!
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
