Old 04-11-2017, 06:19 PM   #1
Joesjunk
Joesjunk's Avatar
Lifting a cab and front clip with a 2 post lift??
Has anyone lifted a complete cab, doors, and entire front clip off the frame in one piece with a 2 post lift? it sounds like it would work other than being front heavy. Thanks
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 04-11-2017, 06:24 PM   #2
BCOWANWHEELS
Re: Lifting a cab and front clip with a 2 post lift??
your asking for big trouble. break it down
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 04-11-2017, 07:32 PM   #3
projectking
projectking's Avatar
If you rigged it properly with 3 points one at bed, cab, and under fenders where the inners mount I'd think it wouldn't be a problem. Hard part would be to get it evenly distributed.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 04-11-2017, 08:35 PM   #4
hugger6933
I use my two post lift to change frames all the time. I did a truck once and left on the front and removed the A/C compressor and sat it in the battery box cause it had stupid cold air and I didn't want to break it down like I normally do.
Last week I used my lift to place a LS motor in a 69 frame,it is nice to raise up the motor 1 inch or so when you are working with slider mounts deciding where the best placement is. In this case it was where the stock driveshaft fit.
I say it can and has been done and the great part of using the lift is you can go super slow and if you want to stop at any point to take a break you are not under any strain at any time. Over the last 30 years I've been building wrecks I've tried every thing possible to raise cabs off trucks that are getting new frames and the two post lift is by far the best.
hugger6933 is offline   Reply With Quote
Old 04-11-2017, 09:20 PM   #5
turp mcspray
turp mcspray's Avatar
I have done it several times as well.
I lift at the cab corner, and front fender cup. Never had any problems!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 04-11-2017, 10:00 PM   #6
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
. It is very easy really easy.Used my buddies lift to do frame clip on a 70 swb.Culvert damage.Everything went as expected.No problems at all.Just have to be smarter than your tools
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 04-12-2017, 08:39 AM   #7
Joesjunk
Joesjunk's Avatar
Thanks, That's exactly what I was looking for. Do you have any pics of where you lifted it at the cab corner?
Old 04-12-2017, 09:45 AM   #8
turp mcspray
Here is the best pic I could find. I lift right under the pinchweld, at the curve.
Turp Mcspray
Old 04-12-2017, 10:10 AM   #9
B. W.
B. W.'s Avatar
lift work well
B. W. is offline   Reply With Quote
