First Ride of the spring, and Carb drainback...
I took my truck out for it's first ride of the spring, and it has sat 3-4 months I suppose.
It took a long time of cranking to get fuel up to the carb bowls, and then it was two pumps and it fired right off. I didn't like all that cranking (maybe 10 seconds total?) because I have a flat tappet cam and, zinc additives or not, I'm scared of wiping a lobe. Is it normal for these to drain/empty like that so that the line is dry and it takes a while to get fuel? Most everything else I have uses an electric pump, so I honestly don't recall!
Re: First Ride of the spring, and Carb drainback...
The pump gas you are buying is probably E10 and it evaporates very fast on vehicles with no EVAP system. Carb bowls vented to the atmosphere can evaporate dry in a few weeks.
'67 GMC 2500, 292, 4spd, AC |
3-4 weeks is a long time to expect gas levels to remain good in your bowls. However, if you are running a Rochester Q-jet, these have been known to get leaks in the factory installed plugs in the bottom of the bowls. When leaks occur, fuel in the bowls drains down into the intake manifold over time, emptying the bowls. I had this issue, and ended up buying the bowl plug sealing kit sold by Cliff Ruggles on his website. Google Cliff's high Performance and you will find it.
I wouldn't worry about flattening any cam lobes during cranking. The oil pump is still moving some oil, and the RPMs you are turning during cranking are pretty low. |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I don't know what you have for a carb but I started my truck up last week after its Winter slumber with no issues. I parked it about the 3rd week of October full of gas with some Stabil included. I think itbmarch 27/28th I unhooked the Batter Tender, checked the oil got in, pumped the gas twice and when I turned the key she started right up on the automatic choke. My truck engine with the exception of a complete Pertronix Unit is stock including the carb.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
I have an additional in line electric fuel pump on a switch for reasons like this,it is mounted on the frame under tyhe truck by my gas tanks, I have two saddle tanks and got rid of the in the cab tank... turn on the pump for a minute or two, gets fuel up to the carb and not cranking on the engine hardly at all...you could mount one underneath your truck also...electric pumps are meant to pump or push gas , so should be mounted fairly close to your tank....
#6 | |
Who Changed This?
![]() Join Date: Jan 2013
Post Whore
![]() Join Date: Feb 2016
As long as your engine is well broke in you don't have to worry about your cam during start up. If you want some piece of mind after a long storage you can take a small funnel and refill the float bowl by pouring about four ounces of gas into the carb bowl vent. Then reinstall the air cleaner before starting.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
On top of evaporation, mechanical fuel pumps will sometimes let some fuel drain back down the pump>carb line after they sit for a bit. I have a newly rebuilt carb and a new AC Delco fuel pump, and if my truck sits for two days, it fires right up on the first or second pump. But if it sits for 5-7 days, it may take several pumps and ~5 seconds of cranking to get it going.
If your truck has been sitting for 3-4 months, as you say, there's no way you're going to have fuel at the carb given evaporation and fuel pump bypass... I'd start wondering about priming the oil pump before a start once it's been sitting that long.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#9 | |
2WD Jimmy
![]() Join Date: Mar 2005
#10 | |
![]() Join Date: May 2013
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Quadrajets are not all created equal. The mid-70's and newer units tend to leak little if any. They have lead plugs in the well openings. It would likely mostly depend on what Q-Jet you have.
Modern gasoline even without ethanol is a whole different animal than gasoline that was in use when most of our classics rolled out from the factory. The stuff evaporates very easily. Every vehicle has it's fuel lines routed differently underneath each vehicle. Some vehicles , making starting different for each. When I start my old car, I first spin the engine, BEFORE I pump the acc. pedal, just to get gas TO the carb. Then I pump it twice, to try to start it. If it does not hit, I turn it over some more, then pump twice again. Usually the second two pumps gets it going. Be careful, if you sit in the car and spin the engine over and continuously pump the acc pedal, it's one of the best ways to flood an engine. You just have to think of what's going on in the process of fuel delivery. As for the O.P. I think you have no problems to worry about, just a normal thing after having sat for an extended time. |
#12 | |
I only have about 400 miles on this engine so I'm still a little sensitive about the cam lobes. The oil pump moving oil does the cam no good, because the lobes are only splash lubricated. But they survived! I have two bottles of CamShield in the current mix.
#13 | |
Post Whore
#14 |
I have a hunch that a lot of us worry about cam lobe wear on flat tappet engines these days. The change in engine oil formulations is probably one of the main reasons that GM went to roller cams in the 90s.
Look at it this way: if your cam develops a flat lobe or two, you've got the perfect excuse to put in a roller cam!
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#15 | |
Who Changed This?
#16 | ||
The bearings are pressure-fed from the oil galleries. The lobes are not. They receive only splash lubrication from crank windage and what little drains out of lifters. Quote:
#17 |
install an electric fuel pump, problem solved
