Old 04-12-2017, 11:57 AM   #1
AirSpeed
AirSpeed's Avatar
New disc calipers and pads won't go on rotor
Replacing my calipers and can't get them to slide over rotor. I compressed the piston as far as it will go but still won't slide over rotor. Checked calipers and pads and they're identical to the new ones. Notice a thin steel "shim" on the back of each pad, even tried to put pads on without them. I used a c clamp and an old pad to compress the piston, looks bottomed out. Any ideas?
AirSpeed is offline   Reply With Quote
Old 04-12-2017, 12:00 PM   #2
AirSpeed
AirSpeed's Avatar
Re: New disc calipers and pads won't go on rotor
Never mind, I'm an idiot! Was using two inside pads!
Old 04-12-2017, 02:07 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: New disc calipers and pads won't go on rotor
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-12-2017, 02:10 PM   #4
AirSpeed
AirSpeed's Avatar
Old 04-12-2017, 02:10 PM   #5
AirSpeed
AirSpeed's Avatar
You don't have to rub it in!😃
Old 04-12-2017, 02:17 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
I was going to say somebody sold you 1'' rotor parts.
But this is way better
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-12-2017, 08:34 PM   #7
rocknss
rocknss's Avatar
At least you didn't do what this guy did!!
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 04-12-2017, 09:08 PM   #8
El Dorado Jim
just had to!!!!! we have all made dumb mistakes like that, I am working on my sm465 transmission now and would have it back together but I pressed the third gear bushing on before putting some of the other gears and washer on first, dumb move, had to break it to get it back off and had to order a new one, should be in tomorrow,,,,,,
El Dorado Jim is offline   Reply With Quote
Old 04-12-2017, 09:10 PM   #9
El Dorado Jim
that is dumb!!!! what was he thinking?
Old 04-12-2017, 09:52 PM   #10
Andy4639
Old member
Andy4639's Avatar
We all have been there done that! If you can't laugh at yourself you have no business laughing at others!
Old 04-13-2017, 11:11 AM   #11
midniteblues
midniteblues's Avatar
I just came across the same thing.
New calipers,hoses and pads for the front of my 71.
Drivers side went together fine.
On to passenger side and i couldn't fit the loaded caliper over the rotor.
Turns out this one caliper is about 1/4" narrower and don't fit.
Now I gotta reorder another.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 04-13-2017, 11:17 AM   #12
davepl
davepl's Avatar
I did that once. I was taking my car in somewhere, got the call a spot was free, had my brakes apart to measure the axle flange, and "threw everything back together" without even a trouble-light. Big mistake.
Didn't make a horrible sound, didn't really drive much different (it was just a couple of miles) but MAN did I feel like an idiot when they saw it!
Then I came on here and told everyone just now :-P It happens...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
