Old 04-12-2017, 06:05 PM   #1
davepl
davepl's Avatar
LS3+6L90E speedometer
I'm trying to figure out the difference between the two speed sensor settings in HPTuners as I try to assist someone in getting a speedometer to work with an LS3-6L90E combo.
Under Hardware, it says:
>> Speed Output Type: VehRepTOS
Then, under Vehicle Speed Sensor, it says:
>> VSS Output: Disabled
First off, can anyone tell me the difference between "Speed Output" and "Vehicle Speed Output"?
I assume one is Transmission -> ECM communication and the other (second one) is ECM -> World and that this is what should be connected to the aftermarket speedo. But I don't want to just enable and wire it without understanding!
Thanks,
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-12-2017, 09:49 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS3+6L90E speedometer
IIRC Speed Output is referring to VSS signal and Vehicle speed out is the speedo output.
On the LS1 cars there is a pin in the harness @ c2-50 labeled Vehicle Speed Output and drives the speedo, cruise control etc. Its the wire that gets used for speed sensing locks etc also.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
