Mcgaughy drop spindles install question
I'm finally making the switch to drop spindles but I was wondering if I would need anything else to install them. I already have the disc brakes on the truck and I know with some of the cheaper spindles, they require different ball joints. Is this the case with McGaughys, or can I just do the switch and roll. I'd appreciate any help
Thanks fellas, Andrew |
Moderator
![]() Join Date: May 2007
Re: Mcgaughy drop spindles install question
What year is the truck and what years are the drop spindles for?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
'70
i just ordered ball joints for a 70, worked on mine
"Send in the clowns the goats are loose" |
I used Western Chassis 2.5 drop spindles on my '70 they fit up with the '70 ball joints and tie rod ends.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
67-72 parts collector,…
![]() Join Date: Nov 2002
You have to order spindles to match the year of ball joints and outer tie rods you are using.
They are sold by the following years: 60-62 63-70 71-72 73-87 light duty 73-87 heavy duty.
I have a set of 2 1/2 drop on mine. bolt on a 72 front end
Thanks fellas, I'm ordering them today!
