Old 04-15-2017, 03:39 AM   #1
buffydores
buffydores's Avatar
Killer 15" Hubcaps
If I wasn't running a set of custom 16" Stockton Rally Wheels, I'd be all over these. In fact, I've never even seen these type of factory 4x4 caps:
http://m.ebay.com/itm/311828595706?_...25.m3641.l6368
You can thank your Uncle Buffy later.
Old 04-15-2017, 01:05 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Killer 15" Hubcaps
I'm old enough to remember them. They were more common on 2wd for sure.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-15-2017, 05:42 PM   #3
rideair
Those hubcaps came in different sizes by adding a mounting plate on the back of them, if memory is correct. I have a set that are as close to NOS as you will find along with the 16.5 inch 8 lug rims/tires(still has the nubs on the tires) Bought them off a guy whose grandfather purchased the 3/4 ton 4x4 truck new, took the truck to a custom wheel shop, had them replaced never to be used again.
Sad part is, now they are just sitting in my shop taking up space after I decided to go a different route.
Old guys and the things we collect ;-)
Enjoy,
rideair is offline   Reply With Quote
