Old 04-15-2017, 07:07 AM   #1
Heggart
Smile 72 GMC steel truck bed assembly questions
Hello all!
When putting my steel truck bed back together, should I use some sort of sealer, gasket material between the wheel Wells and the inner bed wall? Or just prep it and paint it, then bolt it together?
I'm trying to avoid rust, squeaks, etc. Any input would be greatly appreciated!
1972 GMC 4x4 short bed
Factory air, power brakes and steering
350, automatic.
Heggart is offline   Reply With Quote
Old 04-15-2017, 09:29 AM   #2
dfwright
dfwright's Avatar
Re: 72 GMC steel truck bed assembly questions
The assembly manual shows that they put seam sealer between the wheel wells and the bed floor and the bed sides at the factory.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 04-15-2017, 09:41 AM   #3
tim71
tim71's Avatar
I just finished replacing my truck's steel floor. I used 3M strip caulk between where all the metal surfaces meet. The strip caulk is a pain to use, but I followed advice from members here and kept the caulk refridgerated as much as possible. When the caulk is cold it is much easier to pull a strip free and much easier to place where you want it. I was pleasantly surprised how well the bolt holes lined up on the new floor. Heggart, your truck sounds like it is optioned just like mine. Mine is a 71.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 04-17-2017, 07:10 AM   #4
Heggart
Thumbs up Re: 72 GMC steel truck bed assembly questions
Thanks for the advise! I'm pretty much doing a budget, daily driver build. I'm not looking for show quality, just cool and dependable. I'll keep posting pics as I go.
I cut the front half ok out of the floor due to rust, replaced it with a better piece. Cut and welded in new pieces where the bed side bolts to the floor. Ready to sand and get it back together.
Old 04-18-2017, 06:45 AM   #5
Heggart
@Tim- did you paint the pieces before putting together?
Old 04-18-2017, 06:51 AM   #6
Heggart
This is the bed floor welded in. Still have some work to do, but it's a good start and definitely better than it was!
Old 04-18-2017, 08:44 PM   #7
tim71
tim71's Avatar
I was replacing the entire steel floor. The new floor/wheel tubs were primed and the old bedsides had paint/primer on them from original assembly. All metal surfaces that meet had either paint or primer on them and I applied the strip caulk to create a barrier to keep moisture out. I'm doing close to a full restoration on my truck. My original floor was 99% rust free, but 46 years of use had the floor in a wavy and dinged up condition. I didn't want to replace the floor, but was concerned that the bed of the truck with the old floor would not be up to the standards of the rest of the truck. When I reach the point of the bed going back on the frame, I am going to sell the old floor, cross sills/supports, rear pan and wheel tubs on the parts board.
Old 04-19-2017, 06:55 AM   #8
Heggart
Sounds like it's going to be a nice truck! I work hard, and play hard😆 So a full restoration wouldn't serve me well. Sounds like a nice floor. Good luck in your build!
