Please confirm this for me - Body Mounts
Working on swapping a 1987 body onto a 1983 frame I have. I am ordering new body mounts (rubber) to install when i do the swap. I believe I read before that I should use mounts for the frame year, not the body year - so in my case I would need to order the 81-83 style mounts?
Do i have it right? Anyone know the difference or if the 84-87 is a superior design which would still fit the 83' frame? |
Re: Please confirm this for me - Body Mounts
I thought 81up was all the same.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
I'm actually in the process of swapping my cab right now. I got on here to look up what bushings people were using. From what I've seen the 81-87 stuff should all be the same
LMC shows bushings for the 81-83 models, then 84-87 models. This is for a 4x4, although I think that doesn't matter.
Diggin The SquareLife
I wouldnt go by what lmc says... i wouldn't even order from them.....81-87 will work
Who would you guys recommend for good quality body mounts - dont want poly, I do want to use rubber ones.
Robert Olson Transport
![]() Join Date: Oct 2002
Ive used the mounts from ebay and the only difference between the ones on LMC and ebay is the price...
I looked on ebay, all the ones I found are poly material. Brothers also sells rubber ones, I assume they are just the same ones LMC has.
