paint behind the door hinges?
I'm planning on painting my truck with the doors on. Should I put some paint under the hinges and on the pillar before I get them set in place?
![]() Join Date: Jun 2009
Re: paint behind the door hinges?
I surely would otherwise it is unprotected to water that will get behind it
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Doesn't seem like there was paint there from the factory.
If your painting the whole truck spray 2 coats of epoxy everywhere. No better corrosion resistance than epoxy
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
That doesn't mean it was a good idea. Look how much rust is normally behind them also.
![]() Join Date: Oct 2011
Would not the paint act as a sort of a glue and stick and crack when you try to adjust the hinges apon assembly?
can't you just use a marine grease?
