![]() Join Date: Feb 2015
Trailer Hitch Hidden
Hidden trailer hitch project, I started off with a Reese receiver hitch that hung below the step bumper. I installed a sport bumper and it looked out of place. I wanted a hidden hitch that was behind the license plate. Originally I wanted a flip down or up plate to allow the hitch bar to slide into the receiver. After fabbing that up I found I was not able to use a drop or raised hitch ball mount only a straight hitch ball mount, change of plans, I made bracket that holds the license plate and slides into the receiver when the hitch is needed I simply remove the plate and install the hitch bar.
http://67-72chevytrucks.com/vboard/s...d.php?t=693490Cheyenne, AKA "Spare Change" Hack71 Build |
More Pics
![]() Join Date: Dec 2016
Re: Trailer Hitch Hidden
Very clean, looks great, nice work! Thanks for the idea.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Great idea..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Nov 2012
That IS a neat idea. Unfortunately in my state it would not be legal due to the removed tag.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Active Member
![]() Join Date: Feb 2012
nice, clean and useful. I will be stealing your idea.
Clever idea. Look's really nice.
Might be a legal problem, but I don't foresee one. Truck has front plate displayed and trailer plate when towing. Flip up or down plate would not be displayed either. only way around that would be a alternative plate location. I'll let you know if I have any problems. Thanks
![]() Join Date: Mar 2013
Nice idea! if it were a legal issue you could always add a hitch.
blood type; Retumbo
Why not make the plate flip up? It looks to me there is room.
I made my own hitch and the plate flips down. The trailer light hookup is behind plate also
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
I have 2 different trailer heights that I pull occasionally one needs a 2" drop the other needs a 6" rise, I thought about an extension to get past the license plate but tongue weight might be too much on one of the trailers. I don't tow very often with this truck, Ill take my chances with the legal ramifications.
"Trouble" (the law) doesn't find me as often as it did when I was younger!
![]() Join Date: Jul 2015
Looks cleaver, as far as the legal of it though. I had an old welding teacher who is super into the c-10's who's built a bunch of these trucks and his own hidden hitch's. He had his first few with the flip down plate and got pulled over a few times, a flip up plate is still visible in the laws eye. All states require a rear plate, a front plate is not always required. Odd's are if you're not doing anything sketchy or going across the country you'll be ok. Just thought I'd share a story of where it was in fact a problem.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#13 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I screwed a spring loaded gate hinge to the license plate mounting plate and just simply lift the plate and slide in the receiver. Pull the receiver and the plate springs down.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#14 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Flip up Tag here, from a Impala (maybe). No front tags in Florida so a removable one wouldn't work here.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#15 |
neat idea(s) w/ the hitch(s) .... but w/ the tag lifted up, would ve that be something at where you would get a set/pair of disc light(s) behind you and a citation ... ?
dont want to hear excuses, i want to hear solution(s) |
#16 | |
With the tag lifted it's still technically visible in the laws eyes. Pointed at the ground, or not even there is is most definitely not. The Virginia State Police my welding teacher talked to all told him if it was a flip up, then you're good to go. Again, just speaking from what I know in VA.
#17 |
I took the plate off to tow my trailer and got a parking ticket the very first time out. The cop just used the trailer plate number on the ticket, as I had no front plate either. He noted "no plates" on the ticket, but didn't write a fixit ticket for that.
Russ
RC |
#18 |
will probably never use it, the PO had it this way
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#19 |
Florida Edition
The only time it would be up would be towing something. Really not visible from behind but convenient for the officer to read I you did get pulled over.
#20 |
blood type; Retumbo
With mine flipped down a cop can see it from the next lane and not need to stop me. Plus the hitch is between frame rails and up higher in the plate area so it has to be flip down.
