Show me your door speaker hole Repairs
my 72 C20 had 5 inch circular holes cut into the lower door panels for speakers....I yanked the speakers. when I get my new old school replacement radio, I think I'll just do the original center dash speaker which will suit me fine.
Now, I have these big holes to patch. was thinking of getting some sheet metal and cutting circles half inch bigger than holes, paint to match and screw them on to cover holes. What you guys done to repair / patch the holes?? |
#2 | |
I put my midrange drivers in my door holes. Posted via Mobile Device |
Re: Show me your door speaker hole Repairs
If yo go with the patch rout, use the same gauge metal (this could come from a donor door that is too far gone for anything else), trace it out, but leave four or five tabs on the patch to help with welding it in, then tack weld all around the patch, taking your time and going from side to side (this help prevent warping), lead the seams and sand it smooth. Once done, you'll be the only one who know that the hole were there.
![]() Join Date: Mar 2015
In the same boat as you, 2 large holes for speakers in each door. I bought pre cut pieces of carpet from Classic Parts. Since I don't have the welding skills to bring the doors back to original, carpet seemed like the next best thing. Haven't put them on yet, so no pics.
I've got the big holes cut in my doors, too. After contemplating what it takes to repair them, I decided to just get a set of speakers & run 'em in the doors, I've still got my tank behind the seat, so that rules out speakers back there. While the sound quality might not be the best in the doors, I didn't see any reason to reinvent the wheel. Factory resto- yeah, you gotta patch 'em. Otherwise, ask yourself if it's really worth the extra hassle.
Old member
My way of fixing them! I made my own door panels to cover them up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
you have a good point, I asked one welder and he didnt want to try for fear it would warp the metal. I just want it to look clean, so perhaps theres a way to recess the speaker into the door 1/4 inch and then screw a perforated color matched plate over the hole? my luck the speaker would rattle and buzz...LOL.
I personally wouldn't cut a hole in the doors (or dash) for speakers, but I'm going to agree with the guys who say if the hole is already there, put a speaker in it.
Appreciate the thread, I have the same issue plus the radio that was cut out. This is the worst area of my truck for me.
Do you have a 1972 Plaid Pickup?http://67-72chevytrucks.com/vboard/s...d.php?t=635040 Do you have a 1972 Plaid Suburban?http://67-72chevytrucks.com/vboard/s...d.php?t=635033 Do you have a 1972 Plaid Blazer?http://67-72chevytrucks.com/vboard/s...d.php?t=635035 Your Service Manual: http://67-72chevytrucks.com/vboard/s...d.php?t=558016 SPID Thread http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
Just welded my speaker holes up. 6x9 size holes.
PO must of used an air chisel to cut the hole so I cut the hole square and used similar thickness sheet metal for the patch. Just take your time and move around with small welds. Also when grinding move around so you don't put too much heat in the metal. |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#13 |
Oh Wow! your problem was a much bigger problem than mine, guess I shouldn't complain, nice job on the repairs.
#14 | |
![]() Join Date: Nov 2004
The right way
![]() Quote:
With the inner piece cut out, it's super easy to clean up and rust proof the door bottoms!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#15 | ||
![]() Join Date: Apr 2016
#16 | ||
"I ain't nobody, dork."
No lessons here and I have done all of my own fab work and rust repair in my cab. You can check my build thread. I didn't cheap out when I bought a MIG welder and also have an auto-darkening helmet. My bro-in-law is a fabricator and he has always told me, "With a good wire feed gas/no-gas MIG and an auto-darkening helmet... a monkey can weld panels."
I sir... are a monkey. It can be done. ![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#17 |
Cruzin
On the wife's 67 sitting out in the yard one day lol. They made a terrible hole when n they put these in. Got to patch the radio hole too. Sorry no all the way finished pics.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#18 |
You can warp metal pretty easy. I would definitely spend some hours practicing on crap you don't care about. Never use Flux on sheetmetal, way easier to warp it, use the MIG function with gas. Curves and bodylines are "stronger" than flat areas and less likely to warp. Never do more than a tack in an area until it cools.
It's not cheap... my welder was around $500, helmet $75, cart and various welding tools, wire, etc, probably another $200, and it was $225 to "buy" my tank, then it's $40 to get it refilled. I bought my Lincoln from Lowes because I had like $250 in gift cards. My recent project in the background, chopping down a longbed to a shortie.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-19-2017 at 02:42 PM. |
#20 |
Thanks guys. After the tack welds all around, what is the rest of the process like? I see pictures of a bunch of tack welds with gaps between them, and then suddenly the final pictures after the sanding. I suppose it may be what custom10nut calls "lead the seams," is that right? What is that about? Does it use the same machine and wire, and any special technique there? What sort of machine and accessories do you use to sand it flat? What is used to fill in the remaining ripples after you sand and before you paint?
#21 | |
Still Learning
Next I use a mill bastard file to knock down the high spots before actually block sanding the metal with a fresh piece of sandpaper. Then I sand the surface with my DA sander using 120 grit. Please check out this thread from my friend Nuke1 :HERE |
#22 | |
![]() Join Date: Jun 2002
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#23 |
Still Learning
I agree with Rg, Make sure you alternate your tack welds from side to side. Letting it cool adequately. The heat is what will cause warping.
#24 |
finished speaker hole repairs.
#25 |
![]() Join Date: Jan 2007
Nicely done!
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
| Bookmarks |
