04-16-2017, 05:42 PM | #1 |
Hood latch bolt
Has anyone ran into the bolt being to short after installing a cowl induction hood mine is not long enough, do they sell them longer or do i have to weld a longer bolt on it, does anyone know what size it is and the threads per inch Thanks in advance!!
04-16-2017, 05:51 PM | #2 |
Re: Hood latch bolt
Have you adjusted it out longer ?
04-16-2017, 06:42 PM | #3 |
Re: Hood latch bolt
Fiberglass or steel hood?
04-16-2017, 07:03 PM | #4 |
Re: Hood latch bolt
04-16-2017, 07:08 PM | #5 |
Re: Hood latch bolt
04-16-2017, 07:29 PM | #6 |
Re: Hood latch bolt
Stumped. I have a steel cowl hood a no problem with latch. How short do you think it is?
04-16-2017, 09:24 PM | #7 | |
The Older Generation
Re: Hood latch bolt
Does the hood fit the fenders good on both sides, in the front, and/or is there a gap between the hood and grill in the center? I have seen a few reproduction hoods that were evidently in the jig wrong when they were welded and there was a pretty good gap between the hood and grille in the center, at the front of the hood. LockDoc
04-16-2017, 11:01 PM | #8 |
Re: Hood latch bolt
04-16-2017, 11:08 PM | #9 | |
Re: Hood latch bolt
04-16-2017, 11:37 PM | #10 |
Re: Hood latch bolt
04-17-2017, 12:03 AM | #11 | |
Re: Hood latch bolt
As nicklear36 indicated, pictures might help. A straight on shot of the front grill/hood from a kneeling position would be good. Unless you have the wrong year hood pin there is no reason it shouldn't work. If it is the hood pin from your stock hood then it should bolt right in and work like it did with your original hood..... LockDoc
04-17-2017, 10:00 AM | #12 |
Re: Hood latch bolt
No issue on mine.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
