04-16-2017, 07:24 PM | #1 |
Dash cluster.
Restored my dash cluster. Painted needle's. Polished the lens. Question about which gage bulb to hook the wire that powers the shift indicator. Also trailer wire plug. Ever seen one like it?
04-16-2017, 09:46 PM | #2 |
Re: Dash cluster.
Looks really nice! Plug looks like a regular taillight harness plug to me
04-16-2017, 10:11 PM | #3 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Re: Dash cluster.
sub'd
Got the same question about where the shift indicator light powers up from?? |
04-16-2017, 10:12 PM | #4 |
The Older Generation
Re: Dash cluster.
If you have a tilt column it will have a single Grey wire that comes down out of the column housing and connects to a spade terminal by the "CLSTR FEED" fuse in the fuse panel. If you have a non-tilt column you will have a Fiber Optic cable, not a wire and there is a special bulb holder that fits into the location that your pen is pointing to that holds the Fiber Optic cable on that end. LockDoc
04-16-2017, 10:30 PM | #5 |
Re: Dash cluster.
looks like the plug that connects underneath the back of the truck on the frame,connects the front wire harness to the back harness...
04-17-2017, 03:43 PM | #6 |
Re: Dash cluster.
The plug was at the rear most cross member to plug the taillights in. Thanks for the help
04-17-2017, 08:21 PM | #7 |
Re: Dash cluster.
A big ol "Thank You" LockDoc!!
04-17-2017, 10:34 PM | #8 |
Re: Dash cluster.
No problem, glad I could help....
LockDoc
04-18-2017, 01:07 AM | #9 |
Re: Dash cluster.
terry b,
Could you post the steps you went through on your cluster rehab? |
