Old 04-16-2017, 08:27 PM   #1
willy12844
window tint film removal
I was able to take it off my side windows with a razor blade scrapper. My truck has a rear window with a slider window and it as well as each side is some kind of plastic. I'm afraid I'll scratch it with a razor scrapper. Does anyone have a suggestions on what I can do to get the film off?
Thanks,
The pessimist is one who feels bad when he feels good for,
fear he'll feel worse when he feels better
willy12844 is offline   Reply With Quote
Old 04-16-2017, 09:28 PM   #2
hugger6933
Re: window tint film removal
Sometimes if you can grab a corner use some heat[heat gun or hairdryer] and heat the film up it seemed to make it release when I have tried it on windshields before
hugger6933 is offline   Reply With Quote
Old 04-17-2017, 09:56 AM   #3
custom10nut
custom10nut's Avatar
Carefully pull up a corner enough the able to pull on the tint. Then spray warm soapy water in between the film and the glass. This should soften the adhesive so you can peel it without scraping.
custom10nut is offline   Reply With Quote
Old 04-17-2017, 04:54 PM   #4
1stchevy
1stchevy's Avatar
Any window cleaner with ammonia in it will help loosen the glue
1stchevy is offline   Reply With Quote
Old 04-17-2017, 09:44 PM   #5
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Heat gun worked for me.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
