Old 10-19-2003, 11:54 PM   #1
smbrouss70
smbrouss70's Avatar
Smile Question about Dropped Spindles
I'm getting ready to order dropped spindles and disc brakes for my 70 C-10 pickup. I was wondering who made the best spindle for this. I am currently considering ECE or McGaughy's. I want a spindle that will use the original ball joints and tie-rod ends, since I just rebuilt the front suspension about 8 months ago. Also, will I be able to use my factory wheels for now with the 6 lug disc brakes, or will I have caliper clearance issues? Any help will be greatly appreciated.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-20-2003, 09:52 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Either ECE or McGaughys spindles will suit you fine. Both are true bolt on spindles. That said, I just put a set on my 70 and I went with ECE. Several years ago, when I built my 69, ECE was the only name in town for the drop spindles, so I bought a set (about 5 years ago). McGaughys spindles are new on the market, they actually copied ECE's idea. I ordered the ECE spindles again because I know they give great customer service. Plus ECE has the spindles on sale for 220 pr, which is comparable to the McGaughys units.
You will be fine with the stock wheels. They'll fit over the caliper fine.
Kevin
Old 10-20-2003, 11:13 AM   #3
smbrouss70
smbrouss70's Avatar
Thanks, that's just what I needed to know
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 10-20-2003, 11:49 PM   #4
wdz28ss
wdz28ss's Avatar
One vote for ECE for me too. I like 'em.
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had"
wdz28ss is offline   Reply With Quote
Old 10-21-2003, 12:23 AM   #5
smbrouss70
smbrouss70's Avatar
I have talked to Dave at ECE and am completely impressed, he is sincere, knowledgable and just a generally nice guy... not pushy for a sale or anything. I've decided to go with their 4 1/2 - 6 drop (w/ 2" front springs instead of 1 1/2") and will be ordering tomorrow. Thanks for the recommendations.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 10-21-2003, 06:13 AM   #6
Tx Firefighter
I just lowered my truck 4.5/6 last week using ECE stuff. It works perfect!
Old 10-21-2003, 01:58 PM   #7
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
If you have stock 15x7 wheels they wont work! I put McGaughys drop spindles and 6-lug disc brake kit the stock wheels hit the calipers and wouldent turn. I got a set of 15x8 wheels off an 80's 4x4 they work and look good
GMC JUNKIE TOO is offline   Reply With Quote
Old 10-21-2003, 05:09 PM   #8
Frank_Zeller
Frank_Zeller's Avatar
Have McGaughys on mine. No problems. Only complaint would be they did not break the sharp edges after machining. I have the stock steel 5x5 15x6 rims. But I have the the ECE rear 6 drop and sway bar mount and their harware is first class.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 10-21-2003, 07:22 PM   #9
smbrouss70
smbrouss70's Avatar
According to Dave at ECE there were 2 different suppliers of wheels to GM. one fits over the disc brakes and the other one doesn't, I drew this picture to show how the wheels are different on the inside (brake side) the one that steps down will clear and the one that goes up to the wheel center at an angle will not clear. Please excuse the crude drawing, but it gets the point across. I have 2 sets of factory wheels one set should clear and the other shouldn't accrording to Dave. Once my parts come in I'll try them both on to be sure that he is correct.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 10-22-2003, 12:29 AM   #10
GMC JUNKIE TOO
I had the wheels on the left. I wonder why there was a difference in the wheels?
Old 10-22-2003, 06:07 PM   #11
cheyenne10
cheyenne10's Avatar
6 lug wheels
I have noticed 2 styles of 6 lug wheels. One I identified by having rivets on inside face and ones that did not. I think I had the ones with rivets interfere with stock disc brakes. Anyone else observed this?
Bob
cheyenne10 is offline   Reply With Quote
Old 10-23-2003, 10:41 PM   #12
smbrouss70
smbrouss70's Avatar
I have one set of each type of wheels (that I drew), and neither one had rivets... Maybe there was a 3rd type???
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 11-08-2003, 10:45 PM   #13
ZOOMY
spindles
ECE all the way Tried & true.
ZOOMY is offline   Reply With Quote
Old 11-09-2003, 01:13 AM   #14
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I have McGaughy's spindles and love them! Either one will put a smile on your face, BTW The rest of my components are from ECE.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-10-2003, 07:20 AM   #15
GMCPaul
We stock the Classic Drop Spindles manufactured by McGaughy's and all the disc brake and drop components. Since were located in the Central USA you will most likely save a considerable amount in shipping charges on these kits over buying from a west coast supplier as all of these parts are extremely heavy with a set of spindles weighing 52lbs a pair, and rotors weighing 55lbs a pair.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 01-02-2004, 04:12 AM   #16
smbrouss70
smbrouss70's Avatar
Angry BAD NEWS!!
Neither one of the types of original steel wheels would clear the calipers... REALLY ticked me off, but ticked the wife off even more. So in a pinch to be able to drive my truck to work I had to buy the "cheapest" wheels that I could find. Really goofy looking though.
But the suspension is great, can't say enough good things about it.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
