Old 04-17-2017, 03:35 PM   #1
terry b
terry b's Avatar
Photos of interior work
Photos of some interior work today. Dyed the headliner the same color. Dye worked good. Glued it up with liquid nails. Put new woodgrain on the glovebox. Used window cleaner to float the decal around and slow things down. Installed the radio old AM/FM cassette with cb.
terry b is offline   Reply With Quote
Old 04-17-2017, 04:17 PM   #2
raggedjim
raggedjim's Avatar
Re: Photos of interior work
Nice work, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 04-17-2017, 05:52 PM   #3
terry b
terry b's Avatar
Old 04-17-2017, 08:35 PM   #4
kcsa75
kcsa75's Avatar
Glad you figured out how to attach photos.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-17-2017, 09:13 PM   #5
57larry
like the headliner with no trim around it
57larry is offline   Reply With Quote
Old 04-17-2017, 09:25 PM   #6
jocko
jocko's Avatar
Ha! I had to do a doubletake - for a second there I thought you glued woodgrain to the center of the headliner!! I've recovered... Wow, dye turned out really nice, looks good.
Old 04-17-2017, 09:30 PM   #7
custom10nut
custom10nut's Avatar
Nice work on everything. I really like the radio. I found an am/fm 8-track in a truck last week, but didn't get it. Now I think I'm going to go get it. Retro
custom10nut is offline   Reply With Quote
Old 04-18-2017, 12:50 AM   #8
El Dorado Jim
how did you dye the headliner and what adhesive did you use to attach it to the roof, looks great!!! so does your dash..
El Dorado Jim is offline   Reply With Quote
Old 04-18-2017, 06:29 AM   #9
terry b
terry b's Avatar
Kcsa75 could not have figured it out without your help. Thank you!
Old 04-18-2017, 11:17 AM   #10
1968aj
Did you install headliner or trim first? I am about to install mine and want to know best way. THANKS
1968aj is offline   Reply With Quote
Old 04-18-2017, 04:49 PM   #11
terry b
terry b's Avatar
JIM. Bought spray dye from LMC truck. Sprayed four lite coat's on my headliner and visors and door panel's. They turned out nice good coverage. Put the front two pieces of trim up loose. Used liquid nails every six inches in a grid pattern about one inch globes. Stuck headliner to the roof it stayed up on it's own. Moved it side to side and front to back to set glue. Installed back two pieces of trim. Used 1/4 inch plywood covered in paper towels to spread out pressure. Cut 3/4 PVC pipe and fit it between floor and plywood about one inch too long so they would bow and left overnight. Worked great.
