Old 04-17-2017, 05:21 PM   #1
rwdmayhem
possible turbo going out?
My parents have a 2002 GMC 3500 with the duramax. At highway speeds theres a rather high pitched whine that changes with how much your pressing on the throttle. It doesn't seem to make any boost till it hits about 2000rpm either but I can't confirm that as there isn't a boost gauge yet. The oil pressure seems unusually high as well around 70-75psi when cold. It does have 249k miles on it.
rwdmayhem is offline   Reply With Quote
Old 04-18-2017, 10:20 PM   #2
GM-power
GM-power's Avatar
Re: possible turbo going out?
Any power loss? Check your charge air cooler pipes for a leak. Also are there any trouble codes? Nothing abnormal about the oil pressure.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 04-19-2017, 01:07 AM   #3
izzy_Britton
izzy_Britton's Avatar
I had a similar issue on a a work truck some years back, the whine/whiles i was experiencing was from a rip/hole in one of the rubber elbows on the turbo pipes. check that. never know right?
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 04-19-2017, 06:38 AM   #4
95 S_Trucker
95 S_Trucker's Avatar
Also, check for an exhaust leak before the turbo. Exhaust leaks sound a whole lot different when they are before the turbo.
95 S_Trucker is offline   Reply With Quote
Old 04-19-2017, 10:42 AM   #5
rwdmayhem
I'll take a look at the turbo piping when I get a chance.
How would you check for an exhaust leak on the turbo?
Old 04-19-2017, 04:42 PM   #6
95 S_Trucker
Physically look at the manifolds and up pipes.
Old 04-19-2017, 09:18 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You will see trails of soot anywhere you have exhaust leaks on the manifolds or up pipes. You may have to pressurize the intake side to check for boost leaks. Use a regulator and start around 5psi or so and go up. If it's relatively stock, going to 20psi is probably sufficient.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
