Old 04-18-2017, 09:06 AM   #1
jayoldschool
Moderator
65 C10 6cyl battery cable length?
Ordered a new set of cables from my parts guy last week. Went to install them on the weekend, negative is too short, positive is way too long. What length are they supposed to be? Yes, I've measured, I already have crappy parts store ones on there.
jayoldschool is offline   Reply With Quote
Old 04-18-2017, 06:28 PM   #2
jayoldschool
Moderator
Re: 65 C10 6cyl battery cable length?
Ok, I went through the supplier's website to find what I need.
I had:
- 15" negative (too short)
- 65" positive (way too long)
Looked at their other cables, and ordered:
- 20" negative
- 48" positive
I'll update when I get them.
Old 04-18-2017, 06:54 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
You could take an old piece of copper wire and run it along the route you want and use that as a measurement to purchase the correct length. So you dont have to buy things twice.
Or not.
Old 04-18-2017, 07:45 PM   #4
jayoldschool
Moderator
I actually measured before calling the parts place the first time. They sent the wrong stuff.
Old 04-19-2017, 11:10 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
Knowing how expensive these cables are, and in case you haven't placed the re-order yet, I would shorten the positive cable and just order the negative cable.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-19-2017, 07:06 PM   #6
jayoldschool
Moderator
I have a good parts place. I get parts delivered an hour after I call, and I don't pay up front. No problem with the wrong ones, driver picks them up on the next run.
Old 04-19-2017, 07:41 PM   #7
Bears63
...just another truck junkie..
Bears63's Avatar
That certainly makes things easier for you. Great to have a place that works with a person like that.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
