Old 04-18-2017, 10:34 AM   #1
Taylor21293
Taylor21293's Avatar
Cable vs. Linkage Operated Shifters
So I'm in the market for a new shifter for my '71 C10. I tried Googling an answer, but I couldn't seem to find much pertaining to C10's and TH350's, but I want to ask you guys about and pros/cons between cable operated and linkage operated shifters. I plan on taking my truck out to the strip a few times here and there just to mess around, but it won't be a hardcore drag truck or race car. Daily driven, SB350 putting out about 400-450 HP. I love the Lokar Nostalgia series double bend shifters (mostly for the rat rod feel), but I have no idea which setup would be right for my application. Any knowledge and/or opinions, or even other suggestions are greatly appreciated!
Eatin' up Dodges and ****tin' out Fords
Taylor21293 is offline   Reply With Quote
Old 04-18-2017, 06:52 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Cable vs. Linkage Operated Shifters
If you're doing any track time you will need a shifter with reverse lockout. To me... A shifter with a long shaft will be awkward when racing.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-18-2017, 07:48 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Cable vs. Linkage Operated Shifters
Depending on how much racing you actually do will detirmine if you should use cable are linkage. I personally would use linkage for any type of racing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-18-2017, 10:33 PM   #4
Taylor21293
Originally Posted by firedemon View Post
I love my b&m mega haven't had a problem with it at all but I don't hammer on it but I do screw around once in a while its cable
My buddy has one on his Monte Carlo, I thought they only worked well on cars since they're so short. I had a B&M Quiksilver on my 64 Chevelle and it was one of the best shifters I ever had!
