KEEP ON TRUCKING
put in a set of aftermarket gauges got the oil/temp hooked up but where do you hook amp gauge at by the way im running a h.e.i. dist. if that matters.thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Recovering Truck Driver
break most any hot wire that is only on when the ignition is on and put the guage in the middle. Ammeter inline, voltmeter between positive and ground.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
KEEP ON TRUCKING
thanks
My other Love
make sure you put fuse on the guage, nothing worse then having your truck burn to the ground
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
You will want to make sure that your amp meter will take the expected amperage on the wire you hook to . Also, if it is like the factory meter, (shunt type), it will fry at very low amperage.
Jim |
