Old 04-19-2017, 09:34 AM   #1
Hotcorner
Hotcorner's Avatar
Help Identify This Replacement SBC
First post.
Finally bought myself a money pit😄 1972 GMC 1500 Super Custom 350/350.
I'm looking for some help identifying this motor. The suffix does not show up on any of the websites like nastyz28.
Thanks in advance.
Hotcorner is offline   Reply With Quote
Old 04-19-2017, 09:35 AM   #2
67 chevelle
67 chevelle's Avatar
Re: Help Identify This Replacement SBC
GOODWRENCH replacement motor
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-19-2017, 09:39 AM   #3
Hotcorner
Hotcorner's Avatar
Well, yes. But any ideas about the specs? I know it was made in Flynt. Beyond that, don't know. 2 or 4 bolt? Original HP?
Old 04-19-2017, 09:51 AM   #4
B. W.
B. W.'s Avatar
because it's goodwrench engine, info on the stamped #s may be limited. You might want to pull the casting #s & try those. Anyway, looks like a base 350, specs somewhere around 200 HP.
B. W. is offline   Reply With Quote
Old 04-19-2017, 10:01 AM   #5
Hotcorner
Hotcorner's Avatar
Will do before I spend any money on improving the performance.
Since I'm not burdened with keeping the engine original, was contemplating a limited budget performance bump with this as the foundation.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Old 04-19-2017, 10:02 AM   #6
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Here's a link I found. This is for a stock GM Crate motor. : http://www.jegs.com/p/Chevrolet-Perf...52506/10002/-1
Specifications •4-bolt main with 2-piece rear main seal
•Nodular iron crankshaft
•4.000" bore x 3.480" stroke
•Internal balance
•LT1/LT4 powdered metal connecting rods
•Cast aluminum pistons (dished)
•8.5:1 compression ratio
•Hydraulic flat tappet cam (.383"/.401" Lift, 194 / 202 Duration @ .050", and 112° lobe separation)
•Cast iron cylinder heads with 76cc chambers
•1.940" Intake / 1.500" Exhaust valves
•1.250" diameter valve springs
•1.5:1 ratio rocker arms
•3/8" pressed-in rocker studs
•Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - sold separately) - p/n 809-14091563 left side plug; or p/n 809-9421743 right side plug
•4-quart oil pan
•Oil pump, oil pump pickup and oil pump drive shaft installed
•Includes timing tabs for a 6-3/4" or an 8" balancer (balancer not included)
•Recommended spark plug: 14mm thread, .460" reach, 5/8" hex, tapered seat, projected tip (AC Delco p/n 065-R45TS, Autolite p/n 417-144)
•Requires p/n 809-19299222 or p/n 555-23605 Oil filter adapter (not included)
Hope this helps.
If this is the motor you have, it's a great foundation to start with.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 04-19-2017, 10:11 AM   #7
Hotcorner
Hotcorner's Avatar
Hopefully, that's it. The blue paint makes me wonder if this was a crate motor or a warranty replacement. I had read that all GM crate motors are black. I suppose it could've been repainted, but why blue.
Many thanks.
1969 GMC K25
Old 04-19-2017, 10:55 AM   #8
Tator
Not a warranty engine. The suffix code would look different. There would be CE then 6? numbers.
That decodes as built in Flint, Oct. 30 and I would bet that the AJP is a late 1973 350-155hp 2 bolt main. Since it follows AJN. Gm used thousands of suffix codes in buses, boats, motorhomes, etc.
It would not surprise me if there are still some unknown.
Valve covers could be swapped. Check the casting number on the block and the date code if it is there by the oil filter housing.
I would go as far as to pull a valve cover and check the numbers on the head as well.
Tator is offline   Reply With Quote
Old 04-19-2017, 11:11 AM   #9
Hotcorner
Hotcorner's Avatar
I thought the same, but wasn't sure, i.e., a 1973 C60/Omega motor? That's starting to sound like a turd for a foundation.
1969 GMC K25
Old 04-19-2017, 11:17 AM   #10
Tator
I would back up and punt it. It would be as much work and possibly $$ to do a head/cam swap than to R&R a better foundation. If you are going for more hp/tq.
Old 04-19-2017, 11:21 AM   #11
Hotcorner
Hotcorner's Avatar
Yes, I was thinking of heads, cam, headers, and an intake. Keep it simple and mild. 350 ish HP, but maybe this isn't the block to work from.
1969 GMC K25
Old 04-19-2017, 11:47 AM   #12
67 chevelle
The most telling tail will be the head casting number , dont think I would put a top end kit on one of those old goodwrench motors , especially if it has dished pistons . Id opt for an l31 long block and go from there . But thats just me .
Old 04-19-2017, 12:21 PM   #13
CUSTOM/10
CUSTOM/10's Avatar
I would run the engine & head casting numbers and see what they come up as !
Being blue it very well could be a 305 !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-19-2017, 12:32 PM   #14
Hotcorner
Hotcorner's Avatar
Hush your mouth!
1969 GMC K25
Old 04-19-2017, 01:08 PM   #15
Hotcorner
Hotcorner's Avatar
I would note that all of the AJ_ motors are 350 ci.
1969 GMC K25
Old 04-19-2017, 04:15 PM   #16
bruceman1968
bruceman1968's Avatar
AJP = 1985, Truck, 350ci, 160hp, manual trans, 2bbl, LF-5 RPO code, VIN code A, 60 series, federal and California emissions.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 04-19-2017, 05:07 PM   #17
Hotcorner
Hotcorner's Avatar
Good information. I guess they slapped a 4bbl on it for the swap. Anyone known if the LF-5 RPO motor is 4-bolt?
1969 GMC K25
Old 04-19-2017, 06:03 PM   #18
demian5
demian5's Avatar
http://www.mortec.com
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
